Compression due to temperature rise vs volume reduction
The discussion revolves around the differences in pressure changes in sealed tanks due to temperature increases versus mechanical compression. Participants explore the implications of the ideal gas law, the nature of reversible processes, and the effects of adiabatic versus isothermal conditions on gas behavior. The scope includes theoretical considerations and conceptual clarifications related to thermodynamics.
  • Some participants assert that raising the temperature in tank A will double the pressure, while others question the behavior of tank B under mechanical compression.
  • There is a claim that tank B will not return to the original pressure of 14.7 psi, with some participants suggesting that reversible processes may involve isothermal conditions.
  • One participant challenges the assertion that the gas temperature doubles due to compression, introducing the concept of adiabatic processes and the role of heat capacities.
  • Participants discuss the implications of mechanical compression on volume and pressure, with some noting that a permanently reduced volume cannot return to starting conditions.
  • There is a request for clarification on the fundamental differences between pressure increases due to temperature and mechanical compression, with references to the ideal gas law and thermodynamic principles.
Participants express differing views on whether tank B will return to its original pressure and the nature of the compression process. There is no consensus on the implications of adiabatic versus isothermal processes, and the discussion remains unresolved regarding the fundamental differences between the two mechanisms of pressure increase.
Some participants reference the ideal gas law and its limitations, noting that it does not fully address the interactions between pressure, volume, and temperature under varying conditions. There are also mentions of the first law of thermodynamics and the need for a deeper understanding of concepts like internal energy and reversible processes.
This discussion may be useful for students and enthusiasts of thermodynamics, physical chemistry, and those interested in the behavior of gases under different conditions.
escape_velocity
If I have 2 sealed tanks A and B of 1 cu ft volume that contain air at atmospheric pressure and are at 300 deg K. temp absolute.
For tank A I raise the temperature from 300K to 600K and I suppose the pressure will double due to this and would be 14.7 * 2 = 29.4psi absolute
For tank B I use a piston and compress the air in it to 29.4 psi. I don't really know how to calculate the heat of compression in this case.
Now If I allow both tanks to cool to ambient.
Would the pressure in both tanks reduce to atmospheric pressure?
What is the fundamental difference between the pressure increase due to temperature and and pressure increase due to mechanical compression?
Science news on Phys.org
Tank A does return to same pressure.
Tank B has double pressure.
See ideal gas law.
In tank B the compression process "can" be done reversibly and then it follows the ideal gas law. The gas gets twice as hot from the work you do on the piston.
See ideal gas law.
1. Why would Tank B NOT return to the original pressure of 14.7 psi?
2. By reversible compression did you mean isothermal compression?
This is not correct. For adiabatic reversible 2x compression of an ideal gas, the temperature ratio is ##2^{\gamma -1}##, where ##\gamma## is the ratio of the constant pressure- and constant volume heat capacities.
Are you currently taking a course in physical chemistry or thermodynamics? If so, you are probably getting ahead of your current course material. Material like this will be covered later. For now, you are probably learning about the ideal gas law, correct? My advice: just use that for the present to answer the questions that it can address on its own, and wait until later to see how it is applied to more complicated problems.
Chet
Thanks for your explanations
But I really do need to understand this topic, could you kindly explain the true difference between pressure rise due to temperature and pressure rise to do mechanical compression. Even a clue or a reference would do. I would refer to it and then get back if necessary.
Many thanks.
Many thanks.
BvU gave you a good answer at one level, but apparently that was beyond where you are now. Please tell us what level you are approaching this from. For example, are you familiar with the first law of thermodynamics? Do you know what internal energy is? You apparently have never heard the term reversible process. Are you familiar with the term adiabatic process? We need to know this so that we can properly answer you at a level you can understand.
Chet
...Even a clue ...
what does mechanical compression do to volume?
it reduces it?
In a container the rapid motion and collisions of molecules with the walls of the container causes pressure (force on a unit area).Where the motion of molecules depend on temperature.So, the more you rise temperature the more pressure rises.
Mechanical comparison is more simple than that comparison of temperature.Its just an equalization process. When you blow air into a balloon, the balloon expands because the pressure of air molecules is greater on the inside of the balloon than the outside. Pressure is a property which determines the direction in which mass flows. If the balloon is released, the air moves from a region of high pressure to a region of low pressure and the balloon deflates.
My mistake: I did indeed mean reversible isothermal (it's easier on the math) and then the work you do is heat given off to the surroundings. So the gas doesn't get twice as hot.
To be honest, I completely oversaw what Chet points out.
it reduces it?
Right. So, do you know the ideal gas law, and what it says about volume, pressure, and temperature?
it reduces it?
So how can a vessel with a permanently reduced volume return to its starting conditions?
Chet
I am familier with these terms. You could freely use them in your answers.
PV = nRT
In mechanical compression
V would reduce
P would go up
T would go up
If a vessel is permanently reduced volume that is if it is a rigid container. I suppose it would never return to starting conditions.
Are you referring to Tank A the one that we are giving heat to?
OK. So, if you are familiar with all that, please describe in words (qualitatively) what happens in the adiabatic compression of a gas in terms of the heat added to the system, the change in internal energy, and the work done by the system on the surroundings. Then write for us an equation that applies the first law to the adiabatic compression of a gas.
Chet
Escape. In school we usually start with the various gas laws PV=k, P/T = k, P=nk, etc. and come to the Ideal Gas Law PV=nRT. Why? because it is so useful and general.
Its often good for REAL gasses to within a couple of percent (at STP or higher temps and/or lower pressures) and even the worst cases are generally only "off" by 5 or 10% (away from the material's critical points). But it assumes (if you derive it from "fundamental" principles (ie statistical mechanics)) that the gas is composed of point particles which do not interact. Well, how many Angels can dance on the head of a pin? I mean, how many moles, n, of a gas composed of infinitely small point-particles can you add to a tank? Yeah, as many as you want. And according to a beginner's application of the IGL, what you'll change is P (although it doesn't forbid a change in T or in both P & T). But changing T is trickier. There is NOTHING in the IGL which tells you anything about what happens to the other variables when you change one of the FOUR variables. If the problem is expressed carefully, the variables which are independent are declared and the variables which are held constant are also mentioned. In your cases, in tank A, by assumption n and V are held constant and T is increased by 300°. In your tank B, by assumption, n is held constant but now you have two dependent variables T and P and one independent variable, V. It takes more assumptions to conclude that T doesn't drop to 150°K! (which would keep P constant as V is halved). Right? In thermodynamics, which this question is about (mostly), one of the first things you learn about is systems. Open, closed and Isolated are the three most often taught at the elementary level. So in tank A, you add heat and nothing else and then allow heat to escape and then ask what the difference will be. In tank B, you change the volume of the system, allow heat to escape (T to return to 300°) and ask what the difference will be. Its an easy IGL question. for nRT to be constant, then if you have halved V you must double P otherwise PV will not equal P'V'. If you think about it in more pragmatic terms, stepping on a 12 inch piston so that it compresses to 6 inches will NOT! heat the contents by 300°. The actual energy used depends on how the molecules (or atoms if its full of He or something similar)
will heat up as they are crowded...NOT something point-like particles need be concerned with.) (In other words, the fact that a gas changes T as it expands or is compressed is PROOF that atoms (molecules, actually) are not point-like and/or do interact.) Elementary thermodynamics deals with situations where gravity, the weak force, strong force, and even most electromagnetic radiation can be (and is) ignored. (Just picture a tank 1000km high, think pressure will be uniform?? (and how about Temperature? Will T EVER become uniform?(hint: velocity is a measure of kinetic energy = molecular heat, and escape velocity is the velocity at which gravity is "overcome"...). Further information on how T of a gas increases with energy (work, heat) can be found under Heat Capacity in Wikipedia, but reading through it requires a bit of partial differentiation (of simple multivariate equations, f(x,y,z)) which may be something you've not learned yet...(check out the section on diatomic gasses).
So, in Tank A your only change from start to finish is ...nothing (since heat escaped and T goes back to 300°K). In tank B that's not true, you've done work (not handled at all with the IGL!) gotten a T rise then allowed heat (energy) to escape and are left with ½V. Thermodynamics assumes you don't need to know about HOW a process is carried out, that the thermodynamic quantities (these are only a subset of all the variables of a real world system, but a very very useful subset) are ONLY dependent on the initial (starting) state and the final state of the system...(the path to get from initial to final state can vary infinitely). P,V,T and n (by assumption) are thermodynamic variables (when system is "at equilibrium", what ever that means). So, to answer your question about the state of the final system in tank B, if you have the same temperature as initially, the same number of molecules, n, and ½V then P' must be 2P. Worrying about how hot it gets WHILE the system is changing is another story - one involving heat, energy conservation, heat capacities, and doing work on the system. All this goes away, if we just worry about the initial and final state (and don't worry about how we got there). The critical question is: do we have to worry about how we got there? The answer is: if we're worried about the final pressure, no. But if we're worried about how much heat is given off, or how much work was done on the gas, then yes.
The is not correct. Even the temperature of an ideal gas (comprised of point particles) will increase when the gas is compressed adiabatically. Collision of the point particles with the moving piston causes the average kinetic energy of the particles to increase. The piston is doing work on the gas. When we calculate the work done on an ideal gas, we do not take into account the effect of the "crowding" of the molecules, yet we still obtain an increase in the internal energy and temperature of the gas.
Again, this point is not correct.
  • · Replies 20 ·
  • · Replies 23 ·
