Compression of an ideal gas
An ideal gas, Cp = (5/2)R, Cv = (3/2)R, is changed from P1 = 1 Bar and V1t = 12m^3 and V2t = 1m^3 by the following mechanically reversible processes:
a) Isothermal compression
b) Adiabatic compression followed by cooling at constant temperature
c) Adiabatic compression followed by cooling at constant volume
d) Heating at constant volume followed by cooling at constant pressure
e) cooling at constant pressure followed by heating at constant volume
find Q, W, ΔU, ΔH, and sketch a PV diagram for each process.
PV=nRT
For isothermal process (a): Q = -W = RTln(V2/V1)
for isobaric processes: Q = ΔH = ∫Cp dT
Adiabatic Processes: TV^(γ-1) = const, TP^(1-γ)/γ = const, PV^γ = const,
for Isochoric processes: Q = ΔU = ∫Cv dT
I know that ΔU = 0 and ΔH = 0
moles aren't given. I can't find any way to get the initial temperature, which is needed for most of the calculations.
Why is that?
Indeed, there is not enough information. Either give results as a function of ##n## or ##T##, or assume 1 mole.
Since it is an ideal gas, there is enough information because you can express Q, W, ΔU, ΔH in terms of P1, P2, V1, and V2 using nT = PV/R
AM
Right. Forget my previous comment.
Suggested for: Compression of an ideal gas
