Compton Scattering of Electron
The discussion revolves around a homework problem involving Compton scattering of a photon from a free electron. The initial energy of the photon is 0.511 MeV, and the scattering occurs at an angle of 110 degrees. Participants debate the correct application of formulas to find the energies of the scattered photon and recoiling electron, with emphasis on the change in energy and wavelength. There is confusion over the correct interpretation of the change in energy formula, with one participant asserting the validity of their approach while another suggests a misunderstanding of units and algebra. The conversation highlights the need for clarity in deriving the change in wavelength and energy in the context of Compton scattering.
satchmo05
Suppose a 0.511[MeV] photon from a positron-electron annihilation scatters at 110 degrees from a free electron. What are the energies of the scattered photon and the recoiling electron? Relative to the initial direction of the 0.511[MeV] photon, what is the direction of the recoiling electron's velocity vector?
λ2 - λ1 = (h/mc)(1-cos(theta))
change in energy = (hc/(delta(λ)) = h*delta(f)
~ λ2 - λ1 = (h*c)/(m*c2)*(1 - cos(110)) = 0.00326[nm] = delta(λ)
~ variating change in energy formula --> delta(f) = c/(delta(λ)) = 9.2025e19 [Hz]
~ Multiplying frequency by Planck's constant, I get the change in energy = 6.1e-19 [J] = 0.380732094 [MeV]
I am confused at what I do from here to determine the energies of either the scattered photon and the recoiling electron. Since the photon's initial energy is 0.511[MeV], and using change in energy answer from above, would this mean that the energy of recoiling electron be equal to (0.380732094 + 0.511) [MeV]?
Thank you for all help in advance. Hopefully this work I have shown in clear!
Your equation for the change in energy is wrong. Use the fact that
E_\gamma = h\nu = \frac{hc}{\lambda}
Vela, thanks for the reply. There is nothing wrong with that formula that I used earlier. Planck's constant is in units of J*s, and frequency is in s-1. Ergo, energy is in Joules, so my units are fluid. I am not understanding what you're saying. From what I see in your formula, your units for energy would be a Joule*meter, which does not work. Please explain. Thanks.
The formulas I cited are correct. I'm not sure how you're getting joule-meter.
The units in your formula work okay, but algebraically, it's just wrong. The energy of the photons are given by E1=hc/λ1 and E2=hc/λ2, so the difference in energy is
\Delta E = E_2 - E_1 = \frac{hc}{\lambda_2} - \frac{hc}{\lambda_1} \ne \frac{hc}{\Delta \lambda}
Ah, I see what you're saying now. So what would I do with the change in energy value? That was my original question in the statement above. Thanks.
Try looking in your text where it derives the formula for the change in wavelength. Compton scattering is an elastic collision between a photon and an electron.
Vela, I am not finding anything of use to me right now.
Yes, I just read over the text on Compton scattering, and no mention of a formula deriving the change in wavelength. Any help you would be able to give me? Thanks again.
It's an elastic collision, so kinetic energy is conserved.
