Computation of Continued Fractions of irrational numbers
The discussion revolves around the computation of continued fractions for irrational numbers, particularly focusing on the challenges posed by floating point arithmetic and the properties of continued fractions for square roots of integers. Participants explore various methods for calculating continued fractions, including the use of rational arithmetic and the implications of Pell's equation.
  • Some participants note that computer algorithms may yield inaccurate continued fraction expansions due to limitations in floating point arithmetic.
  • One participant presents a method for deriving the continued fraction for \(\sqrt{2}\) and explains the notation used for continued fractions.
  • Another participant provides continued fraction expansions for various square roots, illustrating the periodic nature of these expansions.
  • A theorem related to Pell's equation is introduced, linking periodic continued fraction expansions to solutions of the equation.
  • Participants discuss the impact of floating point accuracy on the computation of continued fractions, with examples showing how different levels of precision affect the results.
  • One participant suggests using rational arithmetic to avoid issues with floating point inaccuracies when calculating continued fractions for non-square integers.
  • Another participant mentions properties of continued fractions for quadratic surds, including the palindromic nature of the repeated sequence.
  • Some participants provide examples of continued fraction representations for mathematical constants like \(e\) and \(\pi\), noting their unique properties.
  • Algorithms for continued fraction calculations are referenced, including Bill Gosper's algorithm.
Participants express a range of views on the accuracy of continued fraction computations and the methods used to derive them. There is no consensus on the best approach, and multiple competing views remain regarding the implications of floating point arithmetic and the properties of continued fractions.
Limitations include the dependence on the precision of floating point arithmetic and the assumptions made in deriving continued fractions. The discussion also highlights unresolved mathematical steps in the computation of continued fractions.
RamaWolf
In this field, computer algorithms may produce false continued fraction expansions because of
the limited accuracy in the floating point arithmetic used. Who knows more?
Let [itex]\sqrt{2}[/itex] - 1 = [itex]\frac{1}{x}[/itex] for x > 0,
or - equivalently - [itex]\sqrt{2}[/itex] + 1 = x, we get the well-known
identity x = 2 + [itex]\frac{1}{x}[/itex], from which we have
[itex]\sqrt{2}[/itex] - 1 = [itex]\frac{1}{x}[/itex] = [itex]\frac{1}{2 + 1/x}[/itex]
Repeated replacement of x = 2 + [itex]\frac{1}{x}[/itex] in the denominator's 1/x
we get the Continued Fraction expression for [itex]\sqrt{2}[/itex] as
[itex]\sqrt{2}[/itex] = [1; 2, 2, 2, 2, 2, ,2 ,2 ...], or in short form [1; (2)]
To explain the short notation of a Continued Fraction here are two samples:
[b[itex]_{0}[/itex]; b[itex]_{1}[/itex], b[itex]_{2}[/itex]] = b[itex]_{0}[/itex]+[itex]\frac{1}{b_{1}+\frac{1}{b_{2}}}[/itex]
[b[itex]_{0}[/itex]; b[itex]_{1}[/itex], b[itex]_{2}[/itex], b[itex]_{3}[/itex]] = b[itex]_{0}[/itex]+[itex]\frac{1}{b_{1}+\frac{1}{b_{2}+\frac{1}{b_{3}}}}[/itex]
Other Continued Fraction expansions are:
[itex]\sqrt{3}[/itex] := [1; 1, 2, 1, 2, 1, 2, 1, 2, ...] or in short form : [1; (1, 2)]
[itex]\sqrt{5}[/itex] := [2; (4)] [itex]\sqrt{6}[/itex] := [2; (2, 4)] [itex]\sqrt{7}[/itex] := [2; (1, 1, 1, 4)]
[itex]\sqrt{8}[/itex] := [2; (1, 4)] [itex]\sqrt{10}[/itex] := [3; (6)] [itex]\sqrt{11}[/itex] := [3; (3, 6)]
[itex]\sqrt{12}[/itex] := [3; (2, 6)] [itex]\sqrt{13}[/itex] := [3; (1, 1, 1, 1, 6)] [itex]\sqrt{14}[/itex] := [3; (1, 2, 1, 6)]
[itex]\sqrt{15}[/itex] := [3; (1, 6)] [itex]\sqrt{17}[/itex] := [4; (8)] [itex]\sqrt{18}[/itex] := [4; (4, 8)]
The solution of Pell's equation is connected to the (periodic) expansion of a specific Continued Fraction by the following theorem due to Lagrange:
Theorem Let x[itex]^{2}[/itex] - N*y[itex]^{2}[/itex] = 1 for a non-square integer N,
let [itex]\sqrt{N}[/itex] have a periodic Continued Fraction expansion of length k,
and let [itex]\frac{s}{t}[/itex] be it's (k - 1)th convergent,
then (s, t) is a solution to the Pell's equation
As an example, we take N = 19 and we try to compute the Continued Fraction (CF) expansion
using different compiler's floating point accuracy:
SQRT(19) = 0.43588 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,3,2,2,3,2,6,1,7,...]
SQRT(19) = 0.4358898 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,8,3,1,2,52,2,3...]
SQRT(19) = 0.435889894 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,8,2,1,3,1,3,396,...]
SQRT(19) = 0.43588989435 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,8,2,1,3,1,2,7,1,5,..]
with no periodicity; only with 13 digits accuracy (or more) we finally have
SQRT(19) = 0.4358898943540 * 10[itex]^{1}[/itex] -> CF = [4; (2,1,3,1,2,8)]
The period length is 6, and for the computation of the 5-th CF convergent we use
the function Inv(q), which reverses numerator and denominator of a rational fraction:
C[itex]_{5}[/itex]([itex]\sqrt{19}[/itex]):=4+Inv(2+Inv(1+Inv(3+Inv(1+[itex]\frac{1}{2}[/itex]))))) := [itex]\frac{170}{39}[/itex]
and x=170, y= 39 is a solution to x[itex]^{2}[/itex] - 19*y[itex]^{2}[/itex] = 1
To avois any issues with the mssing accuracy of the floation point arithmetic, it is suggested
to use accurate 'rational arittmetic' to evaluate the Continued Fraction expansion of a
integer N, not a perfect square.
To this end we use the following
Theorem on rational convergents of a square root: Let N be an integer, not a perfect square,
c[itex]_{0}[/itex] := 1/1 and define recursively, c[itex]_{i+1}[/itex] := [itex]\frac{c_{i}+N/c_{i}}{2}[/itex], we have [itex]\underbrace{lim}_{i->\infty}[/itex] c[itex]_{i}[/itex] -> [itex]\sqrt{N}[/itex]
As an exampel, the rational convergents of [itex]\sqrt{19}[/itex] are:
c[itex]_{1}[/itex] := 10/1, c[itex]_{2}[/itex] := 119/20, c[itex]_{3}[/itex] := 21761/4760, c[itex]_{4}[/itex] := 904035521/207164720
c[itex]_{5}[/itex] := 1632707426270631041 / 374568531156038240,
c[itex]_{6}[/itex] := 5331463645914715901021239526856398081 / 1223121644931491741401139604654015680
Using c[itex]_{6}[/itex] the CF expansion of [itex]\sqrt{19}[/itex] was compute as [4; 2,1,3,1,2,8,2,1,3,1,2,8,2,1,...], establishing this expansion as [4;(2,1,3,1,2,8)]
The rational arithmetc was done using the 'Q' package of my long-integer arithmetic VAR16
Any root of a whole number, or root of a rational for that mater will have a repeated continued fraction as you described. That's true for any quadratic surd ( http://en.wikipedia.org/wiki/Quadratic_surd ). The converse is also true, so if it has repeated coefficients it's of the form (a+b[itex]\sqrt{}c[/itex])/d for some integer values a,b,c and d.
The continued fraction representations for square roots of integers also have an interesting property that the repeat sequence is a palindrome (same forward as backward). The last term of the repeated sequence is always twice the integer part of the square root.
[itex]\sqrt{46}[/itex] = CFS([6L, 1L, 3L, 1, 1, 2L, 6L, 2L, 1, 1L, 3L, 1L, 12L],[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0L])
[itex]\sqrt{71}[/itex] = CFS([8L, 2L, 2L, 1, 7L, 1, 2L, 2L, 16L],[0, 0, 0, 0, 0, 0, 0, 0L])'
[itex]\sqrt{94}[/itex] = CFS([9L, 1L, 2L, 3L, 1, 1, 5L, 1, 8L, 1, 5L, 1, 1L, 3L, 2L, 1, 18L],16)
Other mathematical constants also have interesting representations in continued fractions.
For example e = [ 2; 1, 1, 2, 1, 1, 4, 1, 1, 6, 1, 1,8, ...] = CFS([2,1,2,1],[0,2,0] = CFS([1,0,1],[0,2,0])
[itex]\sqrt{e}[/itex] = [ 1; 1, 1, 1, 5, 1, 1, 9, 1, 1, 13, 1,...] = CFS([1,1,1],[0,4,0])
[itex]\sqrt[n]{e}[/itex] = [ 1; (n-1), 1, 1, (3n-1), 1, 1, (5n-1), ...] = CFS([1, (n-1), 1],[0, 2*n,0])
While [itex]\pi[/itex] does not have a simple 'simple continued fraction' form it does have several nice 'generalized continued fraction' forms.
There are some nice algorithms that deal with calculations using continued fractions. Check out Bill Gosper's algorithm in the unpublished Hakmem http://www.inwap.com/pdp10/hbaker/hakmem/hakmem.html .
Nothing says accuracy like exact arithmetic.
  • · Replies 33 ·
11K
