Compute a derivative using MacLaurin series
The discussion focuses on computing the 9th derivative of the function f(x) = (cos(3x^4) - 1) / x^7 at x=0 using the Maclaurin series. The correct answer is identified as 1224720. A key point is the realization that the n=0 term of the cosine series cancels out the -1 in the equation, allowing for proper manipulation of the series. Participants emphasize the importance of correctly handling series terms and the division by x^7. The conversation concludes with acknowledgment of the mistake in simplifying the series incorrectly.
kamil
Compute the 9th derivative of
f(x) = \frac{\cos\left(3 x^{4} \right) - 1}{x^{7}}
at x=(0)
f(x)=\sum^{\infty}_{n=0} \frac{f^{(n)}(c)}{n!}x^n
cos(x)=\sum^{\infty}_{n=0} \frac{(-1)^{n}}{(2n)!}x^{2n}
The correct answer is 1224720.
I've already read this thread(https://www.physicsforums.com/showthread.php?t=362369&highlight=Maclaurin), and I think I know how to do these kind of problems. However, I have a problem with that one since it has {-1}}
What I did is write the power series for cos(x),
Substitute 3 x^{4} , substract 1, and divide by x^{7}.
And getting:
\frac{\cos\left(3 x^{4} \right) - 1}{x^{7}}=\sum^{\infty}_{n=0} \frac{\frac{(-1)^{n}3^{2n}}{(2n)!}x^{8n}-1}{x^7}
But after that I don't know.
The only term that will produce a nonzero derivative when evaluated at x=0 will have a power of x^9. What is that term and what is it's derivative?
And getting:
Nope. You can't move the 1 inside the sum like that. Sum(something) -1 is not equal to sum(something - 1).
What you should do is recognize that the n = 0 term of the cosine series is 1, so this cancels with your minus 1. Your sum is then from n = 1 to infinity, and you can safely divide the x^7 through. Then I think you probably know what to do from there!
But the n= 0 term for the MacLaurin series for cosine is just "1". The "-1" term just cancels that.
\frac{\cos\left(3 x^{4} \right) - 1}{x^{7}}=\sum^{\infty}_{n=1} \frac{\frac{(-1)^{n}3^{2n}}{(2n)!}x^{8n}}{x^7}
Thank you, it worked. I knew there was something wrong with the -1. I don't know why I thought I could do that operation on a sum. I had also simplified \frac{x^{8n}}{x^{7}} to {x^{n}} , which is totally wrong. I don't why I did this.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 48 ·
