How can COMSOL be used to model convection in a room with a radiator?
  • Thread starter Thread starter adeekay
    Comsol Convection
The discussion focuses on using COMSOL Multiphysics to model forced convection in a room with a radiator for an Acoustical Engineering project. The users are struggling with creating convection currents and have set up a 2D model with specific boundary conditions, but are encountering convergence issues in their transient solution. Suggestions include adjusting boundary conditions to incorporate heat transfer rather than insulation and introducing heat generation to better represent the system. Additionally, incorporating buoyant terms is recommended to observe natural convection effects. The conversation highlights the need for proper modeling techniques and boundary conditions to achieve accurate results in thermal simulations.
adeekay
Hello!
thanks in advance for any help you can throw my way!
I am in my masters year of an Acoustical Engineering course in the UK. We have been set a group design project to with essentially setting up a forced convection cycle in a room in order to redistribute the heat from a radiator and make it more efficient. To model this situation we are (trying) to use COMSOL multiphysics. At the moment we are trying to do it in 2D, with the aim of getting a 3D model in the future.
We have never used COMSOL before, or done anything to do with heat transfer so we're kinda stuck!
The model is very simple; a side view of a rectangular room, with a radiator on one side. We are having trouble making COMSOL create a convection current in the room.
Does anyone have any models that are similar that they could send me to have a look at please?
Secondly, does anyone know of any useful reading (textbooks, websites etc) that would cover this sort of situation? Most of the books in our library detail convection onto a wall etc but not within a room or cavity...
Thank you very much for any help!
Alex
I'm not sure what type of analysis you're doing, but this seems like a fluid dynamic problem. If you're studying forced convection, you'll do the following.
Set up your 2D room, with whatever obstacles, boundaries, etc. Place a heat generation source. Then create your "convection". You can place an inflow boundary somewhere and call it a "fan". Give it a pressure or velocity boundary condition.
Before trying to guess, tell us exactly how you're proceeding with your analysis.
Hi, thanks for the reply.
At the moment we are trying to create natural convection. We are using the general heat transfer and weakly compressible navier stoke modules.
In comsol we have a rectangle of air (subdomain settings loaded from materials library).
The boundary settings for navier stokes are all set to wall/no slip. In general heat transfer the walls are set to insulation/symmetry with the exception of one section which is temperature and that is set to 20 above room temperature.
We found in other forums that because we have a closed system the reference pressure is undefined so we have set the pressure at a point in the top corner.
When we try and run a transient solution it does not converge, but it does calculate for t=0.
If we run a stationary solution the answer returned is the one expected - constant temperature across the subdomain.
The error most likely lies with the volume force Fy in the navier stokes subdomain settings. We have found in the comsol tutorials several different methods for modelling this as the density changes, and we are unsure as to which one is the most appropriate.
I hope this information is useful, thanks very much
Alex
One problem is that your boundary conditions are not right. If you have all insulated walls and impose a temperature, what do you expect your final solution to look like? Well it's going to be all the temp that you defined.
A better way to do this is to give you walls a heat transfer boundary condition if possible. Assume an outside ambient temperature and give it a small convection coefficient. You absolutely need a way to remove heat from the system.
Then, rather than imposing a temperature, give it heat generation. This is a better posed problem that what you were giving it before.
However, note that natural convection is a very small thing to see. You will not see huge convection currents or anything like that. The solution should be a pretty gradual decline in temperature from the source to the boundaries. I do however think you'll need to include bouyant terms to get any effect though.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
