Conceptual Question of Area and Volume
wwshr87
Why the area under the curve of the function y=1/x form 1 to inf is infinite. But if we take this area and revolve it around the y-axis we obtain a volume of pi ?
Because the volume of this rotated solid converges while its surface area diverges. Just because Volume is "one-dimension more" than Area doesn't mean it's "larger." For example, a 0.1m by 0.1m square has an area of 0.01 m^2, but a 0.1 x 0.1 x 0.1 cube has a volume of 0.001 m^3. In your problem, the V_n simple converges quicker than A_n.
Your topic heading said "conceptual question," but here's the math explanation as well if you're curious:
A = \int_1^{\infty} \frac{dx}{x} \ = \ {lim}_{b \rightarrow \ \infty} ( \ ln|x|_1^{b} \ ) = b - 0 = b = \infty.
On the other hand,
V = \int_1^{\infty} \pi(\frac{1}{x})^2 * dx = \pi \int_1^{\infty}\frac{dx}{x^2} = \pi * {lim}_{b \rightarrow \ \infty} [ \ -x^{-1}|_1^{b} \ ] = 0 - (-\pi) = \pi.
Well that makes perfect sense. I knew about the mathematical explanation but was looking for the other explanation you provided. Thank you very much sir.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
