Condition Monitoring: Sensors Used for Electro-Elements in Space Probes
  • Thread starter bill nye scienceguy!
  • Tags
    Condition
In summary, engineers typically use sensors such as encoders, torque-meters, tachometers, pressure sensors, and even variable capacitors or rheostats for condition monitoring in electro-mechanical systems. This includes measuring vibrations, speed, surge, and thrust/pad wear. Commonly used sensors include relative shaft probes, absolute measurement transducers, and speed probes. More information can be found on SKF's website.
127
what kind of sensors do EEs use for condition monitoring in the electro- elements of an electromechanical system? with a view to the subsystems inside a space probe.
Do encoders count as sensors? I mean those that are used for counting the number of rotation of a motor. There are also torque-meters, tachometers, pressure sensors, etc. In some situations they can even use a variable capacitor or a rheosta for those purposes.
By condition monitoring are you referring to vibration & speed monitoring?
We measure various vibrations along gas / steam turbines. We have what we call a relative shaft probe (commonly known as a stinger) which is basically a proximity probe. The probes are gapped electrically to the mid-point operating range of the probe with the shaft jacked so that the probe can measure the gap sufficiently either side of this mid-point (if that makes sense!).
We also use what is known as an absolute measuremnent and the transducer for this is installed on top of the stinger and measures the absolute vibration by the use of an accelerometer (plenty of info on this on google search).
The speed of the machines are measured using speed probes which are 'focused' on a toothed wheel which provides digital pulses to the electronics which determines the speed of the shaft, again, loads of info available on this.
For surge detection and thrust / pad wear monitoring, proximity probes are again used.
This is a VERY basic description. A good place to learn more is on a companies website called SKF.
Hope this helps :)
1. What is condition monitoring and why is it important for space probes?
Condition monitoring is the process of collecting and analyzing data from sensors to determine the health and performance of a system. This is particularly important for space probes as they operate in extreme and unpredictable environments, making it crucial to monitor their electro-elements to ensure they are functioning properly.
2. What types of sensors are typically used for condition monitoring in space probes?
There are a variety of sensors used for condition monitoring in space probes, including temperature sensors, pressure sensors, accelerometers, strain gauges, and vibration sensors. These sensors provide information about the physical and environmental conditions that the electro-elements of the space probe are exposed to.
3. How do sensors used for electro-elements in space probes differ from those used on Earth?
Sensors used for electro-elements in space probes are designed to withstand the extreme conditions of space, such as high levels of radiation and temperature fluctuations. They are also often more compact and have lower power consumption to accommodate the limited space and resources on a space probe.
4. How are the data collected from sensors used for electro-elements in space probes analyzed?
The data collected from sensors on space probes is typically sent back to Earth and analyzed by scientists and engineers. This can involve using specialized software and algorithms to detect any abnormalities or changes in the sensor readings, which can indicate a potential issue with the electro-elements of the space probe.
5. Can condition monitoring prevent malfunctions in space probes?
While condition monitoring cannot completely prevent malfunctions in space probes, it can help detect potential issues early on, allowing for timely repairs or adjustments to be made. This can ultimately help prolong the lifespan of the space probe and ensure its successful operation in space.
  • Electrical Engineering
  • Quantum Physics
