Confused about angular momentum
dyn
Hi. For the angular momentum l=2 case are the L2 and Lz matrices both 5 x 5 matrices with the following eigenvectors ?
## \begin{pmatrix} 1\\0\\0\\0\\0 \end{pmatrix} ## , ## \begin{pmatrix} 0\\1\\0\\0\\0 \end{pmatrix} ## , ## \begin{pmatrix} 0\\0\\1\\0\\0 \end{pmatrix}##,## \begin{pmatrix} 0\\0\\0\\1\\0 \end{pmatrix} ##,## \begin{pmatrix} 0\\0\\0\\0\\1 \end{pmatrix} ##
I am definitely confused about the addition of angular momentum using J = L + S. These are vectors but represented by square matrices ? And also the L and S matrices are usually not even of the same size so how can they be added ? Any help would be appreciated.
The more proper way of writing that sum is ##\mathbf{J} = \mathbf{L}\otimes I + I \otimes \mathbf{S}## where ##I## in the first and second term correspond to the identity matrix in the spin space and orbital angular momentum space, respectively. ##\otimes## denotes kronecker/direct product. The resulting matrices in both terms in that sum will have ##(2l+1)(2s+1) \times (2l+1)(2s+1)## dimension, which determines the dimensionality of the ##J## space.
How do you get to that dimensionality ? I would have thought the 1st term has the dimensionality of the L matrix and the 2nd term the dimensionality of the S matrix which are usually different.
Ps am I right about the l=2 case ?
The basis vector ##|l,m \rangle## and ##|s_z \rangle## live in different space, as you have mentioned, therefore if you want to construct a system in which both spaces interact, the new composite basis vector would be given by the direct product from the two constituent spaces, that is ##|l,m \rangle \otimes |s_z\rangle ## and the linear transformations that act on this new space is also constructed by the direct product.
If you are only working within the l=2 subspace, yes ##L^2## and ##L_z## are 5x5.
Eigenvectors of which operator? If for example you have your ##L_z## diagonal, then they are the eigenvectors of ##L_z##, if it's ##L_x## which is diagonal then they are the eigenvectors of ##L_x##. But the general convention is indeed that, we use the eigenvectors of ##L_z## (and ##L^2##) to span the subspace of a given ##l##.
Likes dyn
Yes these are eigenfunctions of Lz and of L^2.
Not so quick for taking a conclusion. You have to be careful if you are only given a set of eigenvectors in matrix form such as those above. To know which operator (in matrix form), a given set of standard basis vectors (vectors with one element being unity while the rest are zeros such as those above) are eigenvectors of, one has to find one or more matrices which are diagonal. It will be of different issue if you are given already in ket form, namely ##|l,m \rangle##'s, they are certainly the eigenvectors of ##L_z## and ##L^2## because our convention has reserved the number ##m##'s to be the eigenvalues of ##L_z##.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
