I Confused about unit conversion involving natural units
The discussion revolves around converting units for an atomic transition expression, specifically from natural units (Joules) to wavenumber (cm^-1) and the implications of using different constants. The user is confused about converting a term from 1/A (angstrom) to the required units, noting that multiplying by 10^8 would convert to 1/cm. There is a debate on whether to use hc instead of ħc for the conversion, with clarification that spectroscopists define wavenumber as 1/λ rather than k = 2π/λ. The conversation emphasizes the importance of making implicit conversion factors explicit to avoid errors in calculations.
kelly0303
Hello! I have an expression whose natural units are Joules, but all the terms are expressed in terms of cm##^{-1}## (it is for an atomic transition). I have a term in the expression whose units are 1/A (angstrom) and I am not sure how to convert it to what I need. On one hand, if I were to go from 1/A to 1/cm, I would need to multiply that term by ##10^8##. On the other hand, if I want to convert to J, I need to multiply by ##\hbar## c, then convert from J to cm##^{-1}##, which gives ##15927759.569##. The difference between the 2 approaches is ##2\pi##, but I am not sure why. Should I actually use hc instead of ##\hbar##c? The issue is that the formula is defined using ##\hbar## and I am not sure what I am doing wrong. For reference I am talking about equation 1 in this paper (##\alpha_5##, ##A_1## and ##A_2## are unitless). Thank you!
You have implicit conversion factors somewhere. You need to make them explicit. (Well, you don't need to, but the chances of screwing up are smaller if you do)
Likes sophiecentaur
Correct.
Yes. What spectroscopists refer to as wave number is ## 1/\lambda ##, not ## k = 2 \pi / \lambda ##, as theorists often do. In terms of energy (## E=hc/\lambda ##), ##\rm 1 ~eV = 8065.5~cm^{-1} = 1.6022 \times 10^{-19}~J##.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
