Confused High-Schooler Seeks Help Understanding Volt
  • Context: High School
  • Thread starter Thread starter Infinite/Zero
    Confused Volt
7 replies · 2K views
Infinite/Zero
I am a high-school student. My Physics's teacher is not good,so I am here.
Please anyone explain me "What is volt", so that I will have no confusion with Volt.
I will be thankful to you if you clear my confusion.
volt1
vōlt/
noun
noun: volt; plural noun: volts; symbol: V
the SI unit of electromotive force, the difference of potential that would drive one ampere of current against one ohm resistance.
You should learn to use Google. It will answer many such questions for you. If you google something and it still doesn't make sense, then you can ask a more focused question here.
To be able to help you, you need to clearly explain what it is exactly that you are confused with. Just asking such a question and telling us that you have a confusion about it is like telling a doctor that you don't feel well and hoping the doctor gives you an accurate diagnosis.
Have you tried to understand it? What did you read? And what exactly did you not understand that you have read? Did you try googling? Did you go to the Hyperphysics website, for example, to see if they have anything on this?
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elevol.html
Zz.
Matterwave said:
The volt is a unit of measurement measuring the electric potential difference across any circuit element, or more generally between any two points in space.
Matterwave is correct. However, I would also like to add that Volts are equivalent to Joules (J) per Coulomb (C). Joules are a unit used to measure energy, and Coulombs are a unit to measure electric charge. And by the way, there are 6.24x1018 protons/electrons per Coulomb.
I am thankful to all of you for helping me. I have one more question.
What is the relation between Voltage and electric current ?
volt1
vōlt/
noun
Thanks phinds:smile:. I will read all the posts carefully in future. o:)
HyperPhysics is good.Thanks ZapperZ
