Dadface said:
Hello tiny tim and Royal cat.There can be inelastic collisions where all the kinetic energy is lost so what is the correct terminology to use for such collisions?I have always called them completely inelastic but should they be called 100 percent inelastic or something similar.Thank you.
Whoopsie, only just noticed I was replying to a quote by Dadface.
Everything I posted here, with the exception of the first paragraph, is addressed at rice1am. :)
Using the definitions I'm familiar with, such a collision would be defined by two factors.
The first would be that the two colliding objects fuse into one. The second would be that the final velocity of the resulting object is 0.
I think I can see where Dadface was coming from now:
If you work in the center of mass frame (The frame of reference for which the center of mass is at rest), then a plastic collision would result in the loss of ALL the kinetic energy.
To explain further, there are two cases I can think of from the top of my head where a plastic collision would lead to the total loss of kinetic energy : [tex]E_{k_f}=0[/tex]
The first is the case where the initial momentum of the system is 0. The requirement it be preserved coupled with the fact you're only dealing with one mass in the final state, means that your final speed would have to be 0 as well.
Choosing an appropriate frame of reference will bring you to this case. Note that this is a useful transition to make in some cases as it cuts down on the number of expressions you would have to keep track of in an equation.
The second is where you have a single particle of mass [tex]m[/tex] traveling at some velocity [tex]v[/tex] prior to a collision with a particle of mass [tex]M[/tex] which is at rest.
A quick rundown using conservation of momentum would lead to the following conclusion (Try and do this for yourself if you haven't already):
The velocity of the combined particle of mass [tex]m+M[/tex] would be:
[tex]\bar V = \frac{m}{m+M}v[/tex]
Consider the private case where [tex]m<<M[/tex] (Where the mass [tex]m[/tex] is negligible when compared with [tex]M[/tex]), for instance, when a ball of putty hits a wall.
Mathematically, you would have to look at the case where [tex]m\rightarrow 0[/tex]
Taking the limit, you see that the final velocity of the ball of putty+wall will approach 0, meaning the same goes for the kinetic energy of the system.
