Confusing Introductory Electricity Question
To achieve a net electrostatic force of zero on particle 3, it must be positioned on the x-axis, specifically to the left of particles 1 and 2 due to the stronger negative charge of particle 2. The principle of superposition applies, indicating that if particle 3 is equidistant from both particles, the forces exerted by particles 1 and 2 will cancel each other out. The charge of particle 3 is unknown, complicating the calculation of its exact position. The discussion highlights the importance of understanding the forces involved and the application of superposition in electrostatics. Overall, the key takeaway is the need for particle 3 to be strategically placed to balance the forces from the other two charges.
jedjj
In the figure, particle 1 of charge +1.0 µC and particle 2 of charge -2.5 µC, are held at separation L = 7.0 cm on an x axis. If particle 3 of unknown charge q3 is to be located such that the net electrostatic force on it from particles 1 and 2 is zero, what must be the coordinates of particle 3?
x = ? cm
y = ? cm
the figure is not necessary for the question if you know that particle 2 is to the right of particle 1.
F=\frac{kq_1q_2}{d^2}
k=8.99\times10^{9}
Because both particles are on the x axis, to net zero force it must be on the x axis, therefore the y value is 0, and that is correct. I have attempted to use my force equation and found the value as 4.592N(in the negative direction), but that doesn't tell me anything. I also realize that the negative charge is stronger so particle 3 is going to be to the left of the two particles.
Without knowing the charge on particle 3 how can I find this distance?
Thank you in advance.
Principle of super position works
I haven't done a super position problem yet as this course just started a week ago. Can you explain how I would use it here?
EDIT: we covered the idea quickly, but I don't understand how to use it.
EDIT: nevermind. I wasn't looking hard enough through the notes. Sorry!
Basically if particle 3 is equally distant from particle 1 and particle 2, which are in opposite directions of particle the force of the two particles will "cancel out" on particle 3.
It's the same when you did gravity, where the force of gravity on a system of particles follows that same rule.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
