Confusion regarding direction of kinetic friction on inclined plane.
The discussion centers on the confusion regarding the direction of kinetic friction on an inclined plane. The formula for kinetic friction, fk = μkN, remains the same regardless of whether an object is sliding down or up the incline, but the direction of the frictional force is opposite in each case. It is emphasized that friction is a vector, and while the formula provides the magnitude, understanding the direction requires knowledge of the object's motion. The conversation highlights that kinetic friction always opposes the relative motion between surfaces. Ultimately, knowing the direction of the sliding body is essential to determine the direction of the kinetic friction acting on it.
AakashPandita
please help!
The formula for kinetic friction acting on a sliding body is
μkN
When the body is sliding with constant velocity down an inclined plane
fkkN
When the body is sliding up the inclined plane(say due to a force acting parallel to the inclined plane) with constant velocity
even then
fkkN
The direction of kinetic friction is opposite in the 2 cases
while the formula for fk is exactly the same.
If friction is a vector shouldn't the formula for kinetic friction account for its direction too?
For an object that is moving over a surface, the direction of the frictional force is opposite to the direction of relative motion. The coefficient of dynamic friction dictates the magnitude of this frictional force.
For an object that is stationary on a surface, the frictional force will act to oppose any other forces on the object so as to preserve its state of rest relative to the surface. The coefficient of static friction imposes a maximum magnitude on this frictional force.
If the surface is accelerating, a term accounting for that acceleration may need to be added in the static case.
i edited my post a little. could you elaborate please? i am not able to understand how it answers my question.
The formula just tells you the magnitude of the friction force. You also have to know that the kinetic friction opposes the sliding between surfaces.
Okay..
So that means we would always have to know the direction of the body sliding against a surface to tell the direction of kinetic friction acting on it?
AakashPandita said:
Okay..
Yes.
thank you!
