What Are the Key Steps to Solve These Ellipse Problems?
  • Thread starter Thread starter trigger352
    Conics Ellipse
To solve the ellipse problems, the first step is to convert the equations into standard form. For the first problem, the equation 9x^2 + 16y^2 = 144 simplifies to (x^2/16) + (y^2/9) = 1, revealing the center at the origin and the lengths of the major and minor axes. In the second problem, the equation 4x^2 + (y+1)^2 = 9 indicates the center is at (0, -1). Understanding the standard form of an ellipse is crucial for identifying key characteristics. Including textbook references in future posts may enhance clarity and context for problem-solving.
trigger352
Problem I:
(The coeffiecients throw me off, I don't know what I'm supposed to do with them)
9x^2 + 16y^2 = 144
Determine:
a) coodinates of the centre
b) lengths of the major and minor axes
Problem II:
Sketch a graph of the ellipse
4x^2 + (y+1)^2 = 9
PS: For future posts would it be of any help to include the textbook referred to etc?
In this case:
Mathpower 12: WE
Problem I - p. 150 #9
Problem II - p. 150 #19
PPS: I've also italicized any comments about my attemts - since people seem to like to help out people making an attempt.
trigger352 said:
Problem I:
9x^2 + 16y^2 = 144
Determine:
You have to get it in standard form first. Divide both sides by 144.
That gives:
\frac{x^2}{16} + \frac{y^2}{9} = 1
a = length of the major axis
b= length of the minor axis
The clue in both the exercises is to recognize the form of an ellipse with its centre in the origin:
\frac{x^2}{a^2} + \frac{y^2}{b^2} = 1
As mentioned a and b are the lengths of the axes.
In the second exercise the centre is not in origo but (x=0,y=-1).
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
