Conservation of Angular Momentum and a Spinning Bicycle Wheel
A person on a frictionless turntable spins a bicycle wheel horizontally, creating initial angular momentum along the x-axis. When the wheel's axis is tilted upward, the final angular momentum shifts to the y-axis, leading to the person and turntable spinning in the opposite direction. The discussion highlights that while the y-component of angular momentum is conserved, the x-component does not remain constant due to external torques acting on the system from the turntable's axis. Clarification is sought on how these external forces influence the angular momentum, particularly in visualizing the torque from the turntable. Overall, the conservation of angular momentum is contingent on the system's constraints and the presence of external torques.
samirgaliz
A person standing on a stationary friction-less turntable spins a bicycle wheel with the rotation axis of the wheel in the horizontal direction, thus the initial angular momentum is in the horizontal direction (x - axis), say to the right. Now suddenly the person turns the axis of rotation of the wheel by 90 degrees upward (final angular momentum of the wheel is now directed upward along the y- axis).
I understand that the initial angular momentum along the y- axis is zero. Thus we expect the final angular momentum of the system along the y- axis to be zero as well. So the person + platform will spin finally in the opposite direction of the spinning wheel.
But the problem I am having is with the initial x - component of angular momentum. How do we account for a final x- component of angular momentum? If there is no final angular momentum in the x- direction, then this means that angular momentum is not conserved! contradiction! Any help would be appreciated. Thanks.
There will be external forces acting on the system and so you should not expect angular momentum to be conserved in general.
Thanks Orodruin. I did think so but I can not figure out what the external torque is in this case.
The external torque comes from the axis of the turnable. The only direction it cannot provide a torque in is the y-direction (and hence the angular momentum in the y-direction is conserved).
If instead you fixed the entire system to rotate about a single point instead of an axis, then angular momentum with respect to that point would be conserved and the entire system would start spinning in the x-direction as well.
Likes samirgaliz
Thank you.
Thank you Orodruin for you response. I am have difficulty visualising how this force is coming from the axis of the turntable. Any clarification would be appreciated.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
