Conservation of angular momentum help
The discussion focuses on a problem involving the conservation of angular momentum and energy. Participants emphasize the importance of understanding angular momentum, specifically the equation relating linear momentum and angular velocity. A user calculates the angular velocity and height using conservation principles, arriving at specific values for velocity, angular velocity, and angle. Questions arise regarding the correct mass to use in calculations and alternative methods for determining maximum angular displacement. Overall, the thread highlights the need for clarity on angular momentum concepts and problem-solving strategies in physics.
sunumen
http://img215.imageshack.us/my.php?image=q1db9.jpg
I haven't any suggested answer on this problem
The most important thing is that I really don't know how to start to deal with this problem.
< I am lack of knowledge on angular momentum<<I don't know is this needed in solving this problem>> >
I guess that using momentum in the first part finding angular velocity
and use conservation of energy in solving angular displacement??
Can anyone give me some hints?
Thankyou.
Yes. You need to know conservation of angular momentum. \vec{L}=\vec{L_{cm}}+\I\vec{w}.
More simply, as the net torque on the system is negligible, m_1v_1r_1=m_2v_2r_2. From this you find v_2 and the kinetic energy of the system, from which you can find the height and the angle obtained etc.
chaoseverlasting, thanks for your reply.
I have tried to solve the problem in this way.
m_{1}v_{1}r_{1}=m_{2}v_{2}r_{2}
0.02x300x0.4 = 1.02x v_{2}x(0.4+0.5)
v_{2}=2.614m/s
angular velocity= v/r = 2.614/0.9
= 2.9 rad/s
K.E. loss = P.E. gain
1/2 mv^{2} = mgh
1/2 x 2.614^{2} = 9.8 x h
h=0.349m
cos (angle) = (0.9-h)/0.9
angle = 52.24 degree
There are some questions I want to clear
I hope that someone can answer me~~Thx
1~the 1.02(kg) which I highlighted is the sum of the bullet and mass.
Am I incorrect to consider both of them?
I should use 1kg only or 1.02 kg?
If I use 1.02 kg , I think I should consider the center of mass after the bullet embedded...but it is quite troublesome.
2~is there any other solution to find out the maximum angular displacement?
I feel that using conservation of energy may not get the exact solution
moreover, Is there a solution that the angular I found in part a can be used again to solve the angular displacement??
<Speak again, I haven't learn angular momentum before >.< >
Thx any help.
