Conservation of energy and momentum
The discussion focuses on a physics problem involving the conservation of energy and momentum in a system where a box slides into a rolling container. The initial calculations for the box's velocity components before landing in the container were debated, with emphasis on the need to consider both x and y components accurately. It was clarified that momentum is conserved only in the x-direction due to external forces acting in the y-direction. The final velocity of the combined system was derived using the correct application of momentum conservation principles. Overall, the participants confirmed the validity of the final results after addressing the initial misunderstandings.
Lord Dark
An open container of mass 50.0 kg is rolling to the left at speed of 5.0 m/s on a
frictionless surface. A 15.0 kg box slides down a 37° inclined plane and leaves
the end of the plane with speed of 3.0 m/s. The end of the plane is a vertical
distance of 4.0 m above the bottom of the container (see figure). The box lands
in the container and they roll off together.
a- What are the velocity components of the box just before it lands in the container?
b- What is the magnitude and direction of the final velocity of the container?
U1+K1=U2+K2
Pi=Pf
a)U1+K1=U2+K2 (U2=0)
mgh=.5mVo^2=.5mv^2 then i get V=9.35 m/s
b)Vx=(15*7.47)-50*5)/65=-2.12 m/s
Vy=(15*-5.627)/65 = -1.3 m/s
so in (b) i get V=2.12 m/s to the left (removed the Vy because the floor is horizontal)
and in (a) is it right to have U2=0 ?? because the question wasn't specific if the container in the ground or not ,, anyway the picture is in the attachment,,are my answers right ?
That's correct for the magnitude, but you need the components.
I don't understand what you did here. Hint: In what direction is momentum conserved during the collision of box and container?
i got the components and used them in question (b) where Vx=Vcos37 and Vy=Vsin-37 (V=9.35),, the momentum is conserved in the X-axis right ?? because i see that Y-axis just has the block components and there is a floor so the vertical velocity won't count.. is that right ??
This is incorrect. The angle 37° applies only to the initial velocity. By the time the block hits the container the angle will be different.
Yes, momentum is only conserved in the x-direction. (There are external forces--from the floor--acting in the y-direction.)
let see ,, you mean i can distribute Vf into 2 components right .. so the should i divide Vi from the first because Vix=Vfx right ?? so just apply (mgh+.5*m*Viy^2=.5*m*Vfy^2) is this right ??
if it is right I'll get Vix=Vfx=2.4 m/s but Vfy=9 m/s right ?
and from momentum ((2.4*15)-(5*50)=65Vf)) therefore Vf =-3.3 m/s (Vf=3.3 m/s in the container direction) am i right now ? :)
Looks good to me. :approve:
cool ,, thanks very much again :)
