Conservation of Energy/Gravity Problem
  • Thread starter Thread starter tak08810
    Conservation
An object projected upward from Earth's surface at 3.37 km/s is analyzed for its maximum height using conservation of energy principles. The initial potential energy is zero, while the initial kinetic energy is calculated as 1/2 (3370 m/s)². The final potential energy at maximum height is expressed as r * G (M/(R+r)²), with kinetic energy becoming zero at that point. The initial potential energy must be calculated from the Earth's center, leading to the correct formula PE_o = GMm/R. The confusion in calculations resulted in an incorrect maximum height, which should be 6.37×10^5 m.
tak08810
An object is projected straight upward from the surface of Earth with an initial speed of 3.37 km/s. What is the maximum height it reaches?
G = gravitational constant = 6.673x10^(-11) m^3 / (kg s^2)
M = mass of the Earth = 5.9742x10^24 kg
R = radius of the Earth = 6.378x10^6 m
r = max altitude reached (to be determined)
v = initial velocity of object = 3.37 km/s = 3370 m/s
m = mass of the object (numerical value not needed since it will drop out)
Initial Potential Energy = 0 (height is zero)
Initial Kinetic Energy = 1/2 (3370)^2
Final Potential Energy = r * G (M/(R+r)^2)
Kinetic Energy = 0 (velocity would be zero at maximum altitude)
Solving for this, I get the answer as 56700493 m. However the answer is 6.37×10^5 m, what am I doing wrong?
Initial potential energy = 0 (height is zero)
This is not correct. PE of the Earth is measured from the center of the earth.
So the initial potential energy is
PE_o = \frac{GMm}{R}
Ok that makes sense, thank you!
