Conservation of energy of a toboggan problem
A 305kg toboggan traveling at 4.60m/s slows down by 1.10m/s over a 9.00m rough region, prompting a discussion on calculating the average friction force exerted. The initial and final kinetic energy conditions are identified, but the average deceleration needs clarification. The average deceleration is determined to be -0.12m/s², leading to confusion regarding the calculation of friction force. The correct approach involves using the formula v²_f = v²_i + 2ax to find acceleration, confirming the average deceleration. Ultimately, the discussion emphasizes the importance of correctly applying formulas to find the average friction force.
Todd88
A loaded 305kg toboggan is traveling on smooth horizontal snow at 4.60m/s when it suddenly comes to a rough region. The region is 9.00m long and reduces the toboggan's speed by 1.10m/s.
What average friction force did the rough region exert on the toboggan?
I know you can find the initial conditions of the kinetic energy and then the final conditions given the final velocity. I just don't know how to get the force of the rough region. Any help is appreciated.
How much average deceleration of the toboggan was there? You have the initial v, final v and the distance it decelerated by.
-.12m/s
Is that negative velocity? Check your units. Also in the case that is acceleration, then where is the problem of finding the average force of friction? \bar F_f=m \bar a where a is the average deceleration experienced.
It would be simple but am I correct in saying the average acceleration (deceleration in this case) is -.12m/s^2? Because when I do -.12*305 it is not correct. The friction force would be -37.3N which is incorrect.
The correct formula to find acceleration with a distance, and 2 velocities is v^2_f=v^2_i+2ax x=distance, a=acceleration
Ah of course. I knew that. Thanks!
