etothey
- 22
A 194 block is launched by compressing a spring of constant 200 N/m distance of 15cm . The spring is mounted horizontally, and the surface directly under it is frictionless. But beyond the equilibrium position of the spring end, the surface has coefficient of friction 0.27 . This frictional surface extends 85cm , followed by a frictionless curved rise.
No friction on the curved rise, only on horizontal plane.
So basically, box has potential energy in spring, moves over friction surface, then up the hill with no friction, comes back against friction surface, hits the spring, goes to friction surface, and up the hill again, and so on.
kx^2/2=mv^2/2
Ffriction=N*u=mg*u
Vf^2=Vo^2-2ax
kx^2/2=mv^2/2
Solve for initial velocity which is 4,8162m/s.
Solve for deaccelration mg=mau
a=-2.646m/s^2.
Then just calculating the velocity each time he exits the friction surface, moves up, comes down with same velocity, loses velocity at friction surface, hits spring, bounces back with same velocity, enters surface, loses velocity etc.
His final velocity is 0.84m/s moving towards the left at the beginning of the frictionless surface before he comes to a stop.
He will make it 16cm from the right side, in a total of 69cm from the left side.
Is this correct?
Thank you!
