Conservation of energy - olympiad problem
The discussion centers on the elastic energy of a rubber balloon when inflated, specifically addressing the relationship between work done (dW) and change in potential energy (dU). Participants clarify that the correct relationship is dW = dU, rather than dW = -dU, emphasizing the directionality of forces involved. The elastic force, derived from the potential energy change, is equated to the pressure difference acting on the balloon's surface. There is a consensus that using the energy conservation equation simplifies understanding the forces at play. The conversation highlights the importance of accurately defining "elastic force" in the context of balloon inflation.
jpas
When a rubber balloon of spherical shape with un-stretched radius 0 r is inflated to a sphere of radius r ( ≥ r0 ), the balloon surface contains extra elastic energy due to the stretching. In a simplistic theory, the elastic energy at constant temperature T can be expressed byU= 4\Pi {r_0}^2kRT(2 {\lambda}^2+\frac{1}{\lambda^4}-3)
(c) Express ΔP in terms of parameters given in Eq. (2.2), and sketch ΔP as a function of λ = \frac {r}{r_0}In the solution the problem is solved calculating the work, dW, and then making it equal to
\frac {dU}{dr}.dr
But this isn't true. The true equation is
dW=-dU.
Are the solutions wrong?
Why do you think dW=-dU? :smile:
dW=-dU.
Careful. While the force associated with the potential--in this case an elastic force--is given by F = - dU/dr, the change in potential energy is the work done against this force.
Hi,
I think I got it. I'm calculating the force associated with the pressure difference, not the force associated with the potential. These have different directions. Then, because
F_{elastic}=-\frac{dU}{dr} (hooke's law)
\Delta P A = \frac{dU}{dr}
Is that it?
That's right. The force needed to expand the balloon is equal and opposite to the elastic force.
I think we need to clarify "elastic force" here a bit. The "elastic force" we derive from F=-dU/dr is a mathematical quantity equal to -delta(P)*A, while the actual elastic force is tangent to the surface. For that reason, I think we should avoid using F=-dU/dr and instead, use the energy conservation equation dW=dU.
Good point. My point was that the force required to expand the balloon will equal dU/dr, not -dU/dr.
My point was that dW equals (dU/dr)dr , not (-dU/dr)dr. (Equivalent to what you're saying, I think.)
Yes, they're equivalent; both leads to the same result. I just wanted to advise the OP not choose the harder path as it's more complicated to explain the term "elastic force", though your explanation goes to the root.
