Conservation of energy (rotation+translation)
A small solid sphere rolls inside a large hemisphere, and the discussion revolves around calculating its kinetic energy at the bottom and the fraction associated with its rotation. The initial calculations led to a discrepancy in the expected kinetic energy, with one participant suggesting a potential typo in the answer key. The correct height for energy calculations is debated, with some arguing it should be R instead of 2R, but this does not significantly affect the outcome. There is also a discussion about the significance of significant figures in the answer, given the data provided. The conversation highlights the complexities of energy conservation in rotational and translational motion.
mbrmbrg
A small solid sphere, with radius 0.25 cm and mass 0.68 g rolls without slipping on the inside of a large fixed hemisphere with radius 23 cm and a vertical axis of symmetry. The sphere starts at the top from rest. The moment of inertia of a sphere is I = 2/5 MR2.
(a) What is its kinetic energy at the bottom?
(b) What fraction of its kinetic energy at the bottom is associated with rotation about an axis through its center of mass?
E=U+K=constant
U=mgh
K=\frac{1}{2}mv^2+\frac{1}{2}I\omega^2
For part (a) only:
I started to write up the energy conservation law in great and glorious detail, but then I realized that since K_i=0 and U_f=0, and the question only wants to know K at bottom, I could say
mgh=K
(.00068kg)(9.81m/s^2)(0.23m)=K
K=0.00153J
But the correct answer is 0.152J, a rather striking difference. Where did I go wrong?
Your method and answer seem correct to me. (Could be a typo in the answer key or the problem statement.)
Thanks! (the night before the final. Who to trust? My professor's answer key or Doc Al? You got it!)
If you really want to nitpick you can say that the height over which the small sphere is travelling, is not 2R but 2(R-r). It won't make much difference given that R >> r.
That actually occurred to me briefly; but to make a difference of 1e2!
Since its a hemisphere, the height traveled would be R, not 2R. And using a height of R-r, instead of R, would make the KE even smaller--so that won't help!
There's clearly a problem with the orders of magnitude, but I thought the problem was that the book said something of 152 instead of 153...
And concerning the hemisphere, you don't know how it is oriented :-p :blushing:
I wouldn't worry about the third significant figure in the answer, considering that the data given only has two significant figures. :wink:
Lots of luck rolling that ball down the inside of a bowl with a horizontal axis of symmetry! :biggrin: And the problem did state that the axis of symmetry is vertical. :-p
Damn ! I'm not going to talk me out of this one :blushing:
