Conservation of Energy (Spring + Kinetic)
A 3.0 kg mass collides with a spring bumper at a velocity of 3.0 m/s, and the spring constant is 335 N/m. The conservation of energy principle can be applied, equating kinetic energy to spring potential energy. The calculation shows that the maximum compression of the spring is approximately 0.081 m. Both the equations E_kin = E_spring and E_kin(i) + E_spring(i) = E_kin(f) + E_spring(f) are valid, with the latter simplifying to the former in this scenario. The discussion confirms the correct approach to solving the problem.
IB
Tonight I've got so many hard problems...
A 3.0 kg mass slides across a frictionless surface and collides against a spring bumper with a velocity of 3.0 m/s as shown in the diagram. Determine the maximum amount of the spring compresses if it spring constant is 335 N/m.
For this one I don't know whether I should use E_kin = E_spring then solve from there or E_kin(i) + E_spring(i) = E_kin(f) + E_spring(f), but as for the former I got:
1/2 mv^2 = 1/2 k (delta) l^2
mv^2 = k(delta) l^2
(3)(3)^2 = (335) (l^2)
x = .081 m
Is that right? Thanks a lot for your help so far, everyone! I really appreciate your time and kindness. :smile:
looks good.
except the spring epe is .5kx^2
Both the equations are valid. The second one reduces to the first one since E_spring(i) is zero and E_kin(f) is zero.
