Conservation of momentum, confused about variables
In a conservation of momentum lab, students measured the velocities of two colliding objects before and after the collision. The key question revolves around how to express the relationship between momentum before and after the collision in an "if...then..." hypothesis format. The independent variable is the initial velocity, while the responding variable can be either the after-crash velocity or momentum. However, momentum is preferred as it encompasses both mass and velocity, providing a more comprehensive understanding of the system. Ultimately, the discussion emphasizes the importance of momentum in analyzing the outcomes of collisions.
shredder666
In a conservation of momentum lab, two objects were collided together, velocity before and after the collision were measured.
The problem asks how the momentum compares before and after
I'm really confused about the variables here...
In the hypothesis it asks to relate the momentum of a system before and after collision into a "if...manipulated is... then...responding is" format
How do I write it into an if...then... format?!?
I realize that the independent/manipulated variable is the initial given velocity but I'm confused about the responding variable, Is it the after crash velocity or the after crash momentum?
The change in momentum of colliding bodies during collision depends on their masses and their initial velocities. So compare the momentum of each body taking into account its mass and velocity.
well I realize that but I'm more concerned about the responding variable
Is it the velocity or the momentum?
Both.
well... I have to choose from 1 of them... which would be a better answer?
Momentum,. Because it takes into account of both mass and velocity.
