Conservation of Momentum initial velocity curved path
The discussion centers on a physics problem involving the conservation of momentum and the dynamics of a block and putty system on a frictionless track. The initial velocity (v0) of a 1 Kg lump of putty is calculated to be 70 m/s, based on the momentum equation m1v0 = (m1 + m2)(vf) and the normal force acting on the block/putty combination at point B, which is 98 N. The radius of the quarter-circle track is specified as R = 5 m, and the analysis includes the application of centripetal acceleration and energy conservation principles.
  • Understanding of conservation of momentum principles
  • Knowledge of centripetal acceleration and forces
  • Familiarity with energy conservation equations in physics
  • Basic algebra for solving equations
  • Study the derivation of the conservation of momentum equation in collisions
  • Learn about centripetal force and its applications in curved motion
  • Explore energy conservation in mechanical systems
  • Practice solving problems involving normal forces and motion on curved paths
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of momentum and energy conservation in real-world applications.
pconn5
The frictionless track is made of a straight horizontal section and a quarter-circle with radius R = 5 m. A 1 Kg lump of putty is thrown toward the stationary 4 Kg block, and the block starts to slide with the putty stuck on it after the collision. If the normal force acting on the block/putty from the track is 98 N at point B, find the initial speed v0 of the putty.
m1v0=(m1+m2)(vf)
...energy equation?
I have been trying to use the energy equation to solve this problem but I am getting nowhere. The answer is 70 m/s. I can't seem to figure out what the velocity would be at the bottom of the arc. According to a(norm)=v^2/R, I found that v=9.8995 but don't know what to do with that...
Well depending on where B is the velocity would be different.
But say B is just at the bottom of the arc, then on the arc the forces acting are the Normal force R and the weight W. The resultant of these two gives mv^2/r
[tex]\frac{mv^2}{r}=R-W[/tex]
so find v from that.
Then put that into the momentum equation.
Ok I got it now. Thanks for the help.
  • · Replies 19 ·
