Conservation of Momentum not universal?
The discussion centers on the conservation of angular momentum in different reference frames, particularly in circular motion. It highlights that while linear momentum is conserved in all inertial frames, angular momentum is only conserved in frames where there is no net torque. When calculating angular momentum from various points, discrepancies arise due to the presence of torque, which affects conservation. The key takeaway is that angular momentum conservation is contingent on the absence of external torque, and this principle varies with the chosen reference frame. Thus, for a closed system with no external forces, angular momentum remains conserved, while open systems may not exhibit this conservation if they experience net torque.
CHUKKY
So I calculate the momentum of a body moving with a constant speed along a circular path with mass m, tangential velocity v and radius r. Its angular momentum is mvr.kk. Good. Now what if I calculate the angular momentum from a point on the path of the circle. A simple calculation shows that the angular momentum about a point vertically below the center of the circle and which is also on the path of the circle is different for the particle at two different points. e.g. at the the point where the radius of the circle makes an angle with the positive x-axis and the point where the radius of the circle makes an angle zero with the x axis. at the 90 degree point it is 2mvr and at the 0 degree point it is mvr. So does this mean that angular momentum is not conserved in every reference frame?
For circular motion there must be a constant force of \frac{mv^2}{r} towards the center of the circle. When you take your reference frame as the center of the circle then there is no net torque since the force vector is parallel to the position vector, however when you move your reference frame to any other point there will be net torques over parts of the motion.
The key then is to try to pick a reference frame with the least torques involved.
"The key then is to try to pick a reference frame with the least torques involved." so what ur saying is that indeed I did not make a mistake and the momentum is not conserved in all inertial reference reference frame. But I thought the laws of physics were meant to be the same in all inertial refrence frame. So what this means is that in one frame of reference angular momentum is conserved and in another frame of reference angular momentum is not conserved. Or perhaps I am missing the theory. Ok can we say that the laws of physics are universal in that the actual law in analysis should have been that in the absence of a torque, angular momentum is conserved. So since torque was present angular momentum would not be conserved. So is that what it means? You know this is one clear way in which angular momentum differs from linear momentum. In linear momentum, momentum is always conserved in all reference frame.
Angular momentum is only conserved for systems with no net torque on them. That's why if you choose the center point, the angular momentum is conserved, because the force goes through that point and the torque is zero. But if you choose a point on the circle, the force doesn't go through that point, so the torque is not zero. Nonzero torque causes a change in angular momentum. The conservation is only reestablished when you look at the larger system that includes whatever is supplying that torque. A closed system (one with no external forces on it) must have no net torques on it either, so a closed system will always conserve angular momentum. Open systems only do if they are open in such a way that does not experience any net torque, and that's the only issue that is frame-dependent-- the external torque is frame dependent on an open system like something going in a circle.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
