Conservation of Momentum problem-don't understand the solution
The discussion revolves around a conservation of momentum problem involving two pucks on an air-hockey table, where puck A collides with puck B, initially at rest. Puck A has a mass of 0.025 kg and a velocity of 5.5 m/s, while puck B has a mass of 0.050 kg. The challenge lies in determining the final speeds of both pucks post-collision, considering the angles at which they separate. Participants suggest that including a diagram and clarifying the equations used would aid in solving the problem. The thread emphasizes the importance of providing complete information to facilitate understanding and resolution of the physics problem.
skier07
[SOLVED] Conservation of Momentum problem-don't understand the solution
The drawing shows a collision between two pucks on an air-hockey table. Puck A has a mass of 0.025kg and is moving along the x-axis with a velocity of 5.5m/s. It makes a collision with puck B, which has a mass of 0.050kg and is initially at rest. The collision is not head-on. After the collision, the two pucks fly apart with the angles shown in the drawing. Find the final speed of (a) puck A and (b) puck B.
X direction:
Y direction:
Plug into (2)
More Information?
Plug into (2)
No one has posted yet to help you but I think that you should include the drawing and demonstrate what equation (2) is exactly. The lack of information makes your problem difficult to solve...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
