Conservation of Momentum Problem
The discussion revolves around a conservation of momentum problem involving two colliding balls, where one ball is initially at rest. The key equations representing momentum conservation in both the x and y directions are analyzed. It is concluded that the final momentum in the y-direction must equal zero, as indicated by equation III, while the total momentum in the x-direction must equal the initial momentum, as shown in equation V. The correct answer to the problem is identified as option B, which satisfies the conditions of momentum conservation. Understanding how to apply these principles in two dimensions is crucial for solving such problems.
jli10
A ball of mass m_1 travels along the x-axis in the positive direction with an initial speed of v_0. It collides with a ball of mass m_2 that is originally at rest. After the collision, the ball of mass m_1 has velocity {v_1}_{x}{\hat{x}}+{v_1}_{y}{\hat{y}} and the ball of mass m_2 has velocity {v_2}_{x}{\hat{x}}+{v_2}_{y}{\hat{y}}. Consider the following five statements:
I) 0=m_1{v_1}_x+m_1{v_2}_x
II) m_1v_0=m_1{v_1}_y+m_2{v_2}_y
III)0=m_1{v_1}_y+m_2{v_2}_y
IV) m_1v_0=m_1{v_1}_x+m_1{v_1}_y
V) m_1v_0=m_1{v_1}_x+m_2{v_2}_x
Of these statements, the system must satisfy
a) I and II
b) III and V
c) II and V
d) III and IV
e) I and III
(mv)_i=(mv)_f
I've never learned how to incorporate conservation of momentum into a 3-d plane...
a) I and II
b) III and V
c) II and V
d) III and IV
e) I and III
(mv)_i=(mv)_f
This looks like only 2-D to me?
write down the initial total momentum
then write down the final total momentum
then group the X components into one eqn and the Y components in another and see whether you can answer the question.
show your work and we can help
Whoops, sorry, I meant 2-d.
But I think I understand now... You just have to do conservation of momentum for each axis, right? Since the initial momentum is all in the x-direction, the final momentum for the y-components must sum to 0, which is shown in equation III. The initial x-momentum is given by m_1v_0, so the sum of components for the final x-momentum should be exactly that, given by equation V. Final answer (B).
That is correct.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
