Force on Cannon After Firing: Solving the Problem
In summary, for the first question, assuming a frictionless surface, the force on the cannon after firing the cannon ball is 57600N. And for the second question, the energy used by the astronaut throwing the tool is 96 J.
dionysus
1. A 160.0Kg cannon initially at rest shoots an 8.00Kg cannon ball at a speed of 240.0 m/s. The cannon moves backwards 0.40 meters. What is the force on the cannon after firing the cannon ball?
I've solved for the velocity of the cannon, getting 12 m/s, but don't know exactly where to go from there.
2. An 80kg astronaut is in space, at rest. He throws a 5kg tool at 6.0 m/s to another astronaut, with a mass of 65 kg, who catches it.
c. How much energy is used by the astronaut throwing the tool
Is it wrong to use 1/2(m)(v)^2? I used that to get an answer of 90 J, but I've been told the answer was 96 J.
Any help is appreciated, I know this is probably very basic to some of you.
You should post one question at a time. Very little about Physics is basic, in my opinion.
In your first question, assuming a horizontal mount, you have the correct velocity of the cannon moving backwards at 12m/s initially, but it comes to a stop in 0.45 meters. Something has got to stop it, like ground friction or the cannon support. Otherwise, it would move forever. When it stops, it has no more speed. It must therefore have decelerated from 12m/s to 0 in 0.45 meters. One way to solve this problem is to calculate that deceleration, then what would you have to do to solve for the stopping force on the cannon? Or are you familiar with work energy methods?
For the second question, have you considered that the astronaut moves backwards at a certain speed?
Thanks, you were right about the astronaut moving backwards, that solved that problem.
As for the cannonball one, I think I'm supposed to assume its a frictionless surface/system, since I'm given no information about that. With that in mind:
Solving for time: (.4 m) / (12 m/s) = .0333 s
Momentum: (8 kg)(240 m/s) = 1920 kgm/s
Force: (1920 kgm/s) / (.0333 s) = 57600N
Does that seem right assuming no friction/deacceleration?
For momentum I just used mass times velocity, and for force I used impulse (it was at rest to begin with) divided by time.
That's a good way to do it, however, you have used time = distance/speed, whch is not correct. The correct formula is time = distance/average speed. The average speed of the cannon is not 12m/s. It can't get there instananeously from rest, nor can it decelerate to 0 instantaneously. So what is it's average speed? Then calculate the force as you have done, using the correct value for the average speed, which is an average force. Check your work using work energy methods, if you are familiar with that method.
Related to Force on Cannon After Firing: Solving the Problem
What is the force on a cannon after firing?
The force on a cannon after firing is the reaction force generated by the explosion of gunpowder in the cannon, propelling the cannonball forward.
How is the force on a cannon after firing calculated?
The force on a cannon after firing can be calculated using Newton's second law of motion, which states that force equals mass times acceleration (F=ma). The mass of the cannonball and the acceleration due to the explosion of gunpowder can be used to calculate the force.
What factors can affect the force on a cannon after firing?
The force on a cannon after firing can be affected by various factors such as the mass and velocity of the cannonball, the amount of gunpowder used, the angle of the cannon, and external factors such as wind resistance.
Why is it important to calculate the force on a cannon after firing?
Calculating the force on a cannon after firing is important for understanding the trajectory and impact of the cannonball, as well as ensuring the cannon is functioning properly and safely. It also allows for comparisons between different firing methods and can inform improvements in cannon design.
How can the force on a cannon after firing be applied in real-world scenarios?
The force on a cannon after firing can be applied in real-world scenarios such as military operations, where it is important to accurately aim and fire cannons for maximum impact. It can also be used in engineering and design, such as in the creation of more efficient and powerful cannons or the development of other projectile-based weapons.
12K
