- 2,342
- 354
We have Conservation of Energy
We have Conservation of Matter
Is there such a thing as Conservation of Space?
Ranger Mike said:I assume the folowing is not applicable regarding Conservation of Matter?
?The law of conservation of mass/matter, also known as law of mass/matter conservation (or the Lomonosov-Lavoisier law), says that the mass of a closed system will remain constant, regardless of the processes acting inside the system. An equivalent statement is that matter cannot be created/destroyed, although it may be rearranged. This implies that for any chemical process in a closed system, the mass of the reactants must equal the mass of the products. This is also the central idea behind the first law of Thermodynamics.
The law of "matter" conservation (in the sense of conservation of particles) may be considered as an approximate physical law that holds only in the classical sense before the advent of special relativity and quantum mechanics. Mass is also not generally conserved in open systems, when various forms of energy are allowed into, or out of, the system. However, the law of mass conservation for closed systems, as viewed from their center of momentum inertial frames, continues to hold in modern physics.
This seems to ma a rather misleading idea. Isn't it more accurate to say that matter and energy can be converted into one another, while mass remains constant? That's the way I've always spoken of it; mass can be converted from matter to energy and back again, but the mass itself remains constant.ZapperZ said:...if you want to look at the most general form, then it is the conservation of mass+energy, since in many cases, mass and energy can be converted into one another...
Zz.
LURCH said:This seems to ma a rather misleading idea. Isn't it more accurate to say that matter and energy can be converted into one another, while mass remains constant? That's the way I've always spoken of it; mass can be converted from matter to energy and back again, but the mass itself remains constant.
Not trying to be nitpicky, I just think this view promotes a clearer understanding.
Ranger Mike said:Unless I missed something, I have read that there is Matter, Energy and Space in the universe. That is it. ( not going into black holes, dark energy or the like)
Given that Matter = Mass x Volume
Matter has Energy
Matter can be converted to Energy.
Energy has Mass. Energy can be converted to Matter.
Space has Mass and Energy.
My question about conservation of Space was my thinking that the known laws regarding Energy and Matter could be applied or not applied to Space ( The interstellar and intergalactic medium,intergalactic medium what ever you want to call it).
I mean it makes up 99.9 % of the universe and has the least amount of writing on it?
or has this already been done?
Ranger Mike said:We have Conservation of Energy
QUOTE]
could one then say that SPACE is Volume?
That is a good point. There is probably something that you could write down that would be true (at least in Newtonian physics) and you could call "conservation of space".vanesch said:So in order to even consider something like a "law of conservation of space", one should specify in what context, and what exactly one means by that.
The conservation of energy is a fundamental law in physics that states that energy cannot be created or destroyed, but can only be transferred or converted from one form to another.
The conservation of energy applies to everyday life in many ways, such as when we turn on a light switch, the electrical energy is converted to light energy, or when we drive a car, the chemical energy in gasoline is converted to kinetic energy to move the car.
Matter is an essential component in the conservation of energy as energy is stored in matter in various forms such as potential energy in chemical bonds or kinetic energy in the movement of particles.
The conservation of matter and the conservation of energy are closely related as matter can be converted to energy and vice versa, following the principle of mass-energy equivalence stated by Einstein's famous equation, E=mc².
The conservation of space is a concept in cosmology, and it states that space is infinite and cannot be created or destroyed. While it may not directly affect energy conservation, it does play a role in understanding the behavior and distribution of matter and energy in the universe.
