What Is the Van's Velocity After Collision in a Momentum Conservation Problem?
  • Thread starter Thread starter kompheak vic
    Momentum
In a momentum conservation problem, a car with a mass of 15,000 kg traveling at 40 m/s collides with a van of mass 30,000 kg moving at 30 m/s. After the collision, the car reportedly moves backward at 3 m/s, raising questions about the logic of the scenario. Some participants suggest that the car's speed may have simply decreased by 3 m/s instead of reversing direction. Clarification on the problem's wording is recommended to ensure accurate calculations. Understanding the initial conditions is crucial for determining the van's velocity post-collision.
kompheak vic
1 car has mass 15000 drive in velocity 40m/s and 1 van has mass 30000 drive in velocity 30m/s after collision the car go back 3m/s so what is the velocity of the van if the car and the van drive in 1 direction on the street?... i really doubt if the velocity of car is -3m/s
If I understand you correctly, the problem statement tells you that the car bounces back at 3 m/s (and thus its velocity is -3 m/s). Use that fact to calculate the speed of the van after the collision.
but i still don't know why the car hit the van in the speed of 1 direction and the result the car bounce back 3m/s it not logic
It's certainly not realistic data. Perhaps you are misinterpreting what was meant:
kompheak vic said:
...after collision the car go back 3m/s
Perhaps that means the speed of the car was reduced by 3 m/s. That would be much more realistic.
Did you provide the problem exactly as it was given to you, word for word? If not, try to do so.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
