Tinhorn
- 22
- 0
When the box is at the bottom of the incline it will have a velocity of vf
The person is an inertial frame of reference with a velocity of vf
When the person starts moving, the box is moving backwards with the velocity of vf.
This means at the top of the hill the box has both potiental energy and kinetic energy
from the person's point of view.
But when it get to the bottom of the hill, the box has lost all its potiental energy.
It has also lost its kinetic energy because the box and the person are moving at the same velocity.
so now\frac{mv^{2}}{2} + mgh = 0 at the top of the hill
At the top of the hill it had both Kinetic and Potiental energy and at the bottom, it doesn't have any energy.
I'm basically supposed to prove that mgh = \frac{mv^{2}}{2} is still true for an inertial frame of reference
At a stationary frame of reference, normal work does no work.
mgcos(\Theta). Theta always being 90 degrees
but in a moving frame of reference, the displacement is not the same. because to the person
the box looks like its moving left, slowing down and finally catching up. So the angle between displacement and Normal force is no longer 90 degrees.
So in this case Normal Force is definitely doing work.
I'm just stuck in proving that the work normal force does can now make up for the apparent loss of energy.
Meaning:
Finding the work normal force does make \frac{mv^{2}}{2} + mgh = 0 into mgh = \frac{mv^{2}}{2}
What equations should i be looking at ,
Can you point me in the right direction
If you need clarification on something please tell me
