Consevation of energy in collisions
  • Thread starter Thread starter rugapark
    Collisions Energy
Momentum is conserved in all types of collisions, while kinetic energy is conserved only in elastic collisions. Total energy is always conserved, regardless of the type of collision. Inelastic collisions convert some kinetic energy into other forms of energy, such as heat or sound, which is why kinetic energy is not conserved in those cases. Understanding the differences between elastic and inelastic collisions is crucial for answering the question effectively.
rugapark
I am going through some questions for resits in August, and I have no idea what this question is wanting me to explain :
"Briefly discuss the circumstances under which (i) momentum, (ii) kinetic energy and (iii) total energy are conserved in collisions between two bodies. [3]"
it's only a 3 marker, so I'm sure it's not wanting an essay, but I just don't even know where to start... HELP!
Cheers guys
Cheers guys
Thread moved to Homework Help. Here's a hint, rugapark. Check out the terms elastic collision and inelastic collision, and see if that info helps. You can read about them at wikipedia.org, or in your textbook and course materials. Does that get you going again?
Cheers guys
Don't take my word, I'm not the sharpest knife in the drawer, but wouldn't the only case where all three are conserved is in an environment where there is no friction?
so would i be right in saying,
"If the collision between the two bodies is an elastic collision, all momentum, kinetic energy and total energy will be conserved as elastic collisions do not convert any original energy forms into another."
I am struggling to understand this, but I really am determined to get it soon.. so please excuse me if any of my comments seem a little... "crappy" :)
thanks!
thanks!
Yes, that would be right.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
