Constructing a Proportional Growth Equation for Bacterial Population
  • Thread starter glid02
In summary, the conversation discusses the growth of a bacteria culture starting with 820 bacteria and growing at a rate proportional to its size. The population after t hours can be expressed as a function of t, with the correct equation being \frac{dy}{dt}=ky. The conversation also mentions finding the constant of proportionality and using boundary conditions to calculate the constants.
glid02
54
Here's the question:
A bacteria culture starts with 820 bacteria and grows at a rate proportional to its size. After 3 hours there will be 2460 bacteria.
(a) Express the population after t hours as a function of t.
I tried y=y'+820, so -y'+y=820
p(t)=1
mu(t)=e^t
I carried this out (multiplying both sides by mu(t) and finding the integral of both sides) and it's not right.
I really don't even know where to start - is finding mu(t) even the right approach?
Thanks a lot.
Your first equation is incorrect.
The correct equation for this system would be: [tex]\frac{dy}{dt}=ky[/tex], where k is the constant of proportionality; your equation omitted this!
Try integrating this. The numbers are there as the boundary conditions of the system, to enable you to calculate the constants.
Yep, that was it. Thanks.
1. What is an equation?
An equation is a mathematical statement that uses symbols and numbers to show the relationship between two or more quantities. It typically contains an equal sign (=) and can be used to solve for unknown values.
2. Why is constructing an equation important?
Constructing an equation is important because it allows us to represent and solve real-world problems in a concise and organized manner. It helps us make sense of complex information and find solutions to various situations.
3. What are the main components of an equation?
The main components of an equation are the variables, constants, coefficients, and operators. Variables are represented by letters and can change in value. Constants are fixed values. Coefficients are the numbers that appear in front of the variables. Operators are symbols that indicate mathematical operations such as addition, subtraction, multiplication, and division.
4. How do you construct an equation?
To construct an equation, you need to identify the variables, constants, and known values in the given problem. Then, use appropriate mathematical operators to represent the relationship between these quantities. Finally, solve the equation by isolating the variable you want to find.
5. What are some tips for constructing an equation?
Some tips for constructing an equation include reading the problem carefully and identifying the given information, choosing appropriate variables and assigning them clear and consistent labels, and using correct mathematical operators. It is also important to check your equation for accuracy and make sure it makes sense in the context of the problem.
  • Precalculus Mathematics Homework Help
