Context Rich Problem: Thermodynamics: How much ice?
To keep drinks cold in a styrofoam box from 6am to 4pm, it's essential to calculate the right amount of ice needed to maintain a temperature of 0°C. The ice will absorb heat from the outside and the drinks, which may initially be above 0°C, requiring additional ice for cooling. Factors influencing the calculation include the heat flow into the box, the mass of ice, and the initial temperatures of the drinks. Time management is crucial, as accessing resources for data will consume time, impacting the final score. Accurate calculations will ensure sufficient cooling without overspending on ice, allowing for more budget for food and other picnic items.
Nomal
How do you solve the following problem:
You are in charge of keeping the drinks cold for
a picnic. You have a styrofoam box that is filled with cola, water and you plan to
put some 0° ice in it. Your task is to buy enough ice to put in the box at 6am so
that the temperature stays at 0°C until the picnic starts at 4pm. You don't want to
buy too much ice because that means that you'll have less money to spend on food
How much ice will you need? You have 90 ''minutes'' to calculate the amount of
ice, before your cousin picks you up to drive to buy the ice. Getting information
from the resources (on left-hand panel) may cost you some 'time'. The resources
will only cost you '' time'' when you first access them and the cost will be always
indicated. Your score will depend partially on how much 'time' you have left in
your account.
Science news on Phys.org
You need more data. The ice can absorb a certain amount of energy per mass, and if the interior is at 0°C, you have some heat flow from the outside (assuming the air temperature is above 0°C), which depends on the cooling box. If you know this heat flow, you can evaluate the amount of ice you need.
If the drinks initially have a temperature >0°C, you need somd additional ice to cool them. This depends on the amount and temperature of drinks.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
