What Values of C Make the Function Continuous?
In summary, the conversation discusses the process for determining the values of the constant c that will make the function f continuous everywhere. It is important to make sure that the right and left hand limits at the point x=2 are equivalent, which can be found by evaluating the limit as x approaches 2 from both the positive and negative sides. In order for the function to be continuous at x=2, these limits must be equal and also equal to the function's value at x=2.
Arshad_Physic
51
for what values of the constant c is the function f everywhere continous
f(x) cx+7 if x<= 2
(cx)^2 +1 if x>2
i don't understand how to do continuous functions so can someone please explain the
process?
make the right & left hand limit at the point x = 2 equivalent
What is [itex]\displaytype \lim_{x\to 2^_} f(x)[/itex]?
(That's the same as [itex]\displaytype\lim_{x\to 2} cx+ 7[/itex])
What is [itex]\displaytype\lim_{x\to 2^+} f(x)[/itex]?
(That's the same as [itex]\displaytype \lim_{x\to 2} (cx)^2+ 1[/itex])
In order that f(x) be continuous at x= 2, those must be equal and both equal to f(2)= 2c+ 7.
1. What is a continuous limit problem?
A continuous limit problem is a mathematical concept that involves finding the value that a function approaches as its inputs approach a certain value. It is used in calculus to solve for derivatives and integrals.
2. How do you solve a continuous limit problem?
To solve a continuous limit problem, you need to use the properties of limits and apply them to the given function. This involves evaluating the function at the specific value and taking the limit as the inputs approach that value.
3. Why are continuous limit problems important?
Continuous limit problems are important because they allow us to understand the behavior of functions and make predictions about their values at certain points. They also form the foundation for more advanced concepts in calculus such as derivatives and integrals.
4. What are some real-life applications of continuous limit problems?
Continuous limit problems have numerous real-life applications, such as in physics, engineering, and economics. For example, they can be used to model the growth of populations, the rate of change in stock prices, and the speed of objects in motion.
5. Can continuous limit problems have more than one solution?
No, continuous limit problems can only have one solution. This is because the limit of a function is a unique value that the function approaches as its inputs get closer to a specific value.
