Contribution to the magnetic field at the point by a thin wire
The discussion focuses on calculating the magnetic field contribution at a specific point due to a thin wire carrying a current of 9.10 A. The Biot-Savart Law is applied, leading to the conclusion that the z-component of the magnetic field is zero. The participants clarify the cross product calculations, emphasizing that the unit vectors should not be included in the numerical evaluations. After correcting the calculations, the final components of the magnetic field are determined, confirming the accuracy of the approach. The interaction highlights the importance of understanding vector operations in electromagnetic contexts.
theshonen8899
A thin wire carries current along an arbitrary path, but when it passes through the origin, it is in the +y direction. Denote the magnitude of the current is 9.10A and we consider a point in space whose location is r = (-0.730m)*i + (0.390)*k.
Find the contribution to the magnetic field at the point being considered due only to the 0.500mm-long section of the wire centered at the origin.
The answer should be in the following format:
(dBx, dBy, dBz) = [ ] nT
Biot-Savart Law:
(μo/4∏)*[I*(dL x r_hat)/(|r|^2)]
So since there is no z-component in r, Bz should be 0. And since j x j = 0, By should also be 0.
For Bx, dl x r_hat should be r_vector/|r| -\widehat{k} right?
I have a feeling I'm not doing the cross products correctly so I apologize in advance for my difficulty understanding this.
Hello.
It does look as though you are having some difficulty with cross products.
See if this link helps. In particular, look at the example about halfway down that illustrates getting the components of the result.
Likes 1 person
Thanks so much for the response! Okay so let me clarify, dl should be 0.500 mm j_hat right? Since it's on the y-axis.
|r| = √(0.73m^2)+(0.39m^2) = 0.828m
r_hat = (-0.730m/0.828m)*i + (0.390/0.828m)*k = -0.882m*i + 0.471m*k
dl x r_hat = (0.0005m*j) x (-0.882m*i + 0.471m*k)
x = aybz - azby = (0.0005m*j)(0.471m*k) - 0 = 0.0002355m*i
y = azbx - axbz = 0 - 0
z = axby - aybx = 0 - (0.0005m*j)(-0.882m*i) = -0.000441m*k << (from what I understand, j x i = -k right?)
Then plug these values into Biot Savart law:
Bx = (μo/4∏)*[9.10A*(0.0002355m)/(0.828m^2)] = 3.12*10^-10
By = 0
Bz = (μo/4∏)*[9.10A*(-0.000441m)/(0.828m^2)] = -5.85*10^-10
Does that look right? Or at least better?
That's close. But there's still a bit of a problem with how you are calculating the components in the cross product.
You should not be writing the unit vectors when evaluating the components like this.
Just multiply the numbers. These formulas have already taken account of the fact that j x i = -k, etc.
So, you have an incorrect sign in your answer. See if you can find it.
Likes 1 person
Ahh, that would make a lot of sense then. I kept having trouble with cross product signs because I didn't know they already took them into account. So then would it be:
x = aybz - azby = (0.0005m)(0.471m) - 0 = 0.0002355m
z = axby - aybx = 0 - (0.0005m)(-0.882m) = 0.000441m
That looks correct. Good work!
Likes 1 person
Awesome, thanks so much!
