What Are Alternative Terms for Moving a Pickoff Point in Control Engineering?
Alternative terms for "moving a pickoff point" in control engineering include "tap point," while "summing junction" remains the most widely used term. Software packages may have their own terminology, such as "summing block" in MathWorks SimuLink. Other alternatives for "summing junction" include "summing point" and "junction point." The term "node" is also considered a general alternative, but "pick-off point" is more specific for indicating where a signal is observed or redirected. Consistency in terminology is recommended to avoid confusion in documentation.
mech-eng
I would like to ask about some terms of control engineering.
What are other common expressions for "moving a pickoff point" which can be used as" moving a pickoff point behind of a block" or as "moving a pickoff point ahead of block."
Source:Self-made
Thank you.
"pick-off point" seems good enough. "tap point" is one alternative.
What are the other common expressions for "summing junction" ?
Thank you.
Thank you.
"summing junction" is probably the most common term used. If you use a particular software package, there may be a similar term. MathWorks SimuLink calls them a "summing block". But MATRIXx SystemBuild calls them a "summing junction".
PS. If you are writing something, I recommend that you avoid a variety of terms and just use one standard term all the way through. I have spent hours upon hours wondering if some term in a document meant something different from another similar term, when they really meant the same thing.
Some people use "summing point" or "junction point" instead of "summing junction" so what do you think about these alternatives?
Thank you.
Could "node", too, be alternative of them ?
Thank you.
mech-eng said:
Could "node", too, be alternative of them ?.
"node" is a good general term. If you want to imply that the node is a place where a signal is being observed or split off to another place, "pick-off point" implies that and is better.
I am not sure but some people might call summing junctions as substractors.
Thank you.
  • · Replies 17 ·
  • · Replies 24 ·
