Convergence and uniformly convergence question
  • Thread starter Thread starter thesaruman
    Convergence
thesaruman
For what range of positive values of x is \sum_{n=0}^\infty \frac{1}{1+x^n}
(a) convergent
(b) uniformly convergent
I didn't figure out how to separate convergence and uniformly convergence for this series.
My idea was to consider two different intervals: x in [0,1] and in (1,\infty).
For the first interval,
\frac{1}{1+x}+\frac{1}{1+x^2}+\cdots + \frac{1}{1+x^n}\ge \frac{n}{1+1};
and therefore, is divergent.
For the other one, I considered a similar idea,
\frac{1}{1+x}+\frac{1}{1+x^2}+\cdots + \frac{1}{1+x^n}\le \frac{n}{1+x};
but for this series be convergent, is necessary that x > n.
So, please, can anyone give a little help here?
How do I decide about the convergence? And uniform convergence?
your second comparison is not helpful, try instead
1/(1+x)+1/(1+x^2)+...+1/(1+x^n)<1/x+1/x^2+...+1/x^n=(x^(n-1)-1)/(x^n-x^(n-1))
It makes not sense to compare x and n the way you do, because n takes an infinite number of values.
Convergence is uniform if N can be chosen without regard to x.
Thanks, lurflurf. Your idea was of a great help. But the uniform convergence is still giving me headache. I was thinking that if I could prove that the sum \sum \frac{1}{1+x^n} is a monotonically decreasing function, for any value of n, then the bigger the x, smaller the sum, so It would be necessary less terms for establishing the convergence, and this way, this series wouldn't be uniformly convergent. What do you think?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
