What is the Convergence of the Geometric Series with Common Ratio 1/2?
andrey21
Show what:
sum n.(1/2)^n
converges to
Now I know that sum (1/2)^n converges to 2 so can I use this some how
Jamiey1988 said:
Show what:
sum n.(1/2)^n
converges to
Not really, but knowing what sum x^n is and taking a derivative with respect to x would help.
Im sorry could u explain that a little more please.
1+x+x^2+x^3+...=f(x) for |x|<1. What is f(x)? Now differentiate both sides.
well f(x) is x^n.
so differentiting gives:
n.x^(n-1) = 1+ 2x + 3x^2 + 4x^3...
Jamiey1988 said:
well f(x) is x^n.
f(x) isn't x^n! f(x) is the sum of the geometric series x^n. f(x)=1+x+x^2+x^3+x^4+... out to infinity. There's no 'n' in the answer. What formula do you use to sum an infinite geometric series?
s infinity = a/1-r correct?
a/(1-r) is right if the series is a*r^n. What is it if the series is x^n?
Am I meant to manipulate the existing formula or is there a separate one, if so I havnt come across it.
Manipulate the existing formula. x^n is a*r^n when a=1 and r=x, isn't it?
Rite so doing that I obtain:
1/(1-x)
differentiate:
1.(1-x)^-1
-1.(1-x)^-2
correct??
1/(1-x)
differentiate:
1.(1-x)^-1
-1.(1-x)^-2
correct??
Close, but no. You are forgetting the chain rule part of the calculation. d/dx (u)^(-1)=(-1)*u^(-2)*du/dx. What's the du/dx part?
Ah so would that make it (1-x)^-2??
Ok. So put the two things together. 1/(1-x)^2=1+2*x+3*x^2+4*x^3+... Now what's the difference between the series on the right side and the series you want to sum n*x^n?
Well the right hand series is equivalent to:
n+1 (x)^n correct?
n+1 (x)^n correct?
Right. Suppose you multiply both sides by x? Does that get you closer to what you want?
So that would give x/(1-x)^2 = x + 2x^2 +3x^3...
Ok, so might that help you to solve the given problem?
Erm I don't see how that relates to:
n.(1/2)^n
Am i missing something obvious?
n.(1/2)^n
Yes, you are missing something REALLY obvious. Put x=1/2 in the formula you just derived.
Well that gives:
1/2 /(1-1/2)^2
1/2 / 1/4
= 2 correct??
Jamiey1988 said:
Well that gives:
1/2 /(1-1/2)^2
1/2 / 1/4
= 2 correct??
Correct.
SO that is what the series converges to??
Why would you think not?? Isn't the series 1*(1/2)^1+2*(1/2)^2+3*(1/2)^3+ etc? Isn't that sum n*x^n for x=(1/2)? Didn't we show that is x/(1-x)^2? Where along the line did I lose you??
No I was just confirming that's all. Thank u for all ur help :)
