Convergence of 1/K?: Tests & Solutions
  • Thread starter Thread starter Destroxia
    Convergence
The series Σ (1/k!) converges to the mathematical constant e. The convergence can be established using the ratio test, which confirms that lim (n→∞) (a_{n+1}/a_n) = 0, indicating convergence. The divergence test, which states that if lim (n→∞) a_n ≠ 0, the series diverges, is also discussed, clarifying that a limit of 0 does not provide conclusive evidence of convergence. The discussion emphasizes the importance of correctly applying convergence tests to determine the behavior of series.
  • Understanding of series convergence and divergence tests
  • Familiarity with the ratio test for series
  • Knowledge of factorial notation and its properties
  • Basic understanding of limits in calculus
  • Study the ratio test in detail, focusing on its application to various series
  • Explore the divergence test and its implications for series analysis
  • Learn about the properties of the exponential function and its series representation
  • Investigate other convergence tests such as the comparison test and root test
Students of calculus, mathematicians analyzing series, and educators teaching convergence concepts will benefit from this discussion.
Destroxia
Does (1/(k!)) converge?
[/B]
Convergence Tests?
I thought I could just simply use the divergence test, but I'm not sure if that only tells you if it's divergent and not whether it is convergent or not.
lim(k>inf) (1/(k!)) = 0, if L =/= 0, then it is divergent, but since it is 0 does that make it convergent, or inconclusive?
I've thought about trying a comparison test but I'm not sure what I could compare 1/k! too, would I compare it to 1/k? In which case it would be divergent.
Kinda stuck here on which to use.
Are you wondering about the convergence of the series ##\Sigma_{k=0}^\infty \frac{1}{k!}##
We can set ##e^x=\Sigma_{k=0}^\infty \frac{x^k}{k!}##. Then ##e^1=\Sigma_{k=0}^\infty \frac{1^k}{k!}=\Sigma_{k=0}^\infty \frac{1}{k!}##
So, the series converges and equals ##e##.
While it is true that \sum \frac{1}{k!} converges to e, if you did not know that initially, you could have used the "ratio test": \sum a_n converges if \frac{a_{n+1}}{a_n}< 1 and diverges if it is greater than one.
(Your test, that if \sum a_n converges, the a_n, must go to 0, is generally called the "divergence test" since it tells us that if that limit is NOT 0 then the series diverges but does NOT tell us one way or the other if the limit is 0.)
I don't think you stated the ratio test quite right. The ratio test tells us that the series converges if lim_{n->\infty} \frac{a_{n+1}}{a_n} <1. The series the OP asked about certainly passes this test, since lim_{n->\infty} \frac{n!}{(n+1)!} = lim_{n->\infty} \frac{1}{n+1} = 0. You wrote that the ratio test is that the series converges if \frac{a_{n+1}}{a_n} < 1. The series \sum_{n=1}^\infty \frac{1}{n} would pass this test since \frac{a_{n+1}}{a_n} = \frac{n}{n+1} < 1 for all n, but it does not converge. The ratio test for this series gives lim_{n->\infty} \frac{a_{n+1}}{a_n} = lim_{n->\infty} \frac{n}{n+1} = 1
