Convergence Test: Solving Homework on (n!)/(2n)!
lmannoia
It's from sum (n=1, to infinity.. I apologize for not knowing how to type it in properly!) of (n!)/(2n)!
We're supposed to use either the Root Test or the Ratio Test to determine if the series converges or not. My problem is that I don't know how to break up (2n!) so that it'll cancel with (n!). Any hints are appreciated. Thank you!
If you use the ratio test, you shouldn't have to worry too much about breaking up the (2n)! term.
Hint: when you see factorials, always try the ratio test.
Looking at it again, I figured it out. Thanks for the hint, too!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
