Converging nozzle temperature difference - Steady flow energy equation
Nuclear_eng
I come from a civil engineering background and I'm about to start a masters in nuclear energy. I have no experience in thermodynamics and I've been doing a bit of revision before the course commences to get me up to speed. I've been working my way through 15 revision questions and I only have a couple left now. I posted a question on this forum yesterday but I'm stuck again with a different type of question on flow processes. This is meant to be one of the easiest questions in my revision booklet but so far the answer has eluded me.
A converging nozzle is used to accelerate a flow of air from 50m/s at the inlet to 150m/s at the exit. The air temperature is 25°C at the inlet. Assuming heat transfer to the air is negligible, use the steady flow energy equation to calculate the temperature at the exit.
Steady flow energy equation:
h1+0.5V12+gZ1=h2+0.5V22+gZ2
I've revised control volume analysis and steady flow processes but I'm not getting anywhere with this. I assume it will be a very simple calculation as all the other 'easy' revision questions have taken me about a minute or two.
The correct answer is 15.1°C
Is there no one who can help me? I've been looking at this similar question I found on the forums and I can't get 184°C by using the SFEE. I think I must be making a mistake with the units or something really stupid.
https://www.physicsforums.com/showthread.php?t=249494
Could somebody please just plug the numbers in and show me how he got 184°C? I would imagine it will take less than a minute and it would be a massive help to me.
Thanks
Use the energy equation you have above. The enthalpy is Cp*T. Ensure you get the units correct on the V^2/(2g) term.
15.1 C is indeed correct.
Thank you very much Lawrence. I was getting my units for Cp messed up but I've now managed to get 15.1°C.
