Convert PSI to Pascals & Compare to Atmospheres
  • Thread starter Thread starter Big Drop
Converting pressure from psi to pascals provides a clearer perspective on force comparisons. For instance, 200 psi equals approximately 1.38e10^6 Pa, which translates to about 13.6 atmospheres. An atmosphere is defined as 14.7 psi or 101,325 Pa, making this conversion essential for understanding pressure levels. The discussion emphasizes that while converting to pascals and then to atmospheres is not strictly necessary, it aids in demonstrating calculations. Ultimately, the pressure in the engine is over 13 times greater than atmospheric pressure.
Big Drop
Pascals - Atmospheres
I have a various numbers of psi's...and was told it would be interesting to convert it to pascals, and then compare the pascals and our atmosphere.
As in, 200 psi is 1.38e10^6 Pa. How could i show how much force that is. Or even say, its 'x' number of atmospheres. Just so i can get the pressure into perspective for readers...Thanks
Pressure is just force / area, hence PSI is pounds / square inch, Pascal is 1N/m^2
An atmosphere is roughly 15psi or 100KPa.
To convert PSI to Pa you just need to know how many pounds in a Newton and how many sq inches in a square metre.
Ahhh yes. Must have missed these figures!
14.7psi = 1 atmosphere = 101,325 Pa
And its 6.894 757 kPa to 1 psi.
So if i were to write a sentance would something like this be correct?
"The pressure at combustion is 200psi. To show how high this pressure is, i converted it to Pascals, which is 1.38e10^6 Pa, and then converted Pa to atmospheres which is 13.6. This means that the pressure in the engine is over 13 times as strong as our atmosphere."
By the way, i know i don't have to convert to Pa, then to atm, but as i would show working, it would tick a box.
I am a bit wary of my last sentance, comparing the two. It doesn't sound good to me...i was trying to think of a better way to describe it really.Thank you very much for all your help!
Pressure is 13 times greater than the atmosphere.
thanks for the help! much appreciated.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
