Converting between scientific & regular notation, without changing sig. figs.?
To convert 3.60 x 10^5 to regular notation without changing significant figures, the correct representation is 360,000, which has three significant figures. However, this raises concerns about the significant digits, as 360,000 typically indicates only two significant figures. The discussion highlights that 3.60 x 10^5 implies a value range of 359,500 to 360,500, maintaining three significant figures. To accurately express the uncertainty, it is suggested to indicate it as ± 5,000. The conversation emphasizes the importance of preserving significant figures in scientific notation conversions.
rishay95
According to the question, i have to convert 3.60 * 105 to regular notation, without changing the number of significant figures, which is currently, as i understand, three.
I'm just really unsure how to do this.
Any help?
Some said to write out 360,000 & use a bar on the leftmost zero. But, the textbook doesn't mention bars so I'm not sure if we're allowed to use them. Is there any other solution?
If it were 3.6 * 105, I know it would just be 360,000
However, that 3.60 is what's really messing me up.
360,000 is still correct. 3.6 x 10^5 means that the actual value is in the range from:
355,000 to 365,000.
Whereas 3.60 x 10^5 means that the actual value is in the range from:
359,500 to 360,500.
355,000 to 365,000.
359,500 to 360,500.
Thanks for the reply, but doesn't the value 360,000 have 2 significant digits? That would be changing the number of significant digits, which according to the question, I am not allowed to do.
To specify 2 sig digs, write the uncertainty after the value.
For 3.6 x 10^5, the uncertainty would be ± 5,000.
That means the uncertainty for 3.60 x 10^5 is...?
