Converting Ions into Electricity
  • Thread starter Thread starter Drakkith
    Electricity Ions
Converting moving ions into electricity, known as Direct Energy Conversion, involves capturing the energy from high-speed ions, particularly those from fusion reactions. The discussion highlights that any charged particle, including ions, can generate electricity, similar to how batteries operate. Participants suggest exploring test equipment that performs these conversions and reference existing literature for further understanding. The process typically involves slowing down high-energy ions to harness their energy effectively. Overall, the conversation emphasizes the need for more detailed resources and explanations on this topic.
Drakkith
Mentor
Hey all. I'm trying to find more info on converting moving ions into electricity. AKA Direct Energy Conversion. Anyone know any good sources? I don't really understand how they do it yet, even after reading a few things I found on google.
You must be referring to high energy ions, right??
That I'm not familiar with, but ions moving in an electrolyte is how a battery works...as well as corrosion in salt water...and wiki has reading material...there have also been discussions here in the forums recently...
In general any charged particle, that is any ion, can produce electricity...
Have you considered checking how test equipment works?? They make such conversions.
I'm referring to high speed ions, the kind that come from fusion reactions. I was wondering how you can convert them into electricity simply by slowing them down and capturing them. That seems to be the simplified explanation from what I can tell. I just have no idea why that works.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
