Converting Wavelength to Nanometers
  • Thread starter Thread starter jcvince17
To convert a frequency of 2.8 x 10^14 Hz into wavelength in nanometers, the formula λ = c/f is used, where c is the speed of light (approximately 3 x 10^8 m/s). By applying the formula, the wavelength is calculated as λ = 3 x 10^8 m/s / 2.8 x 10^14 Hz, resulting in a wavelength of approximately 1.07 x 10^-6 m or 1070 nm. The discussion highlights confusion regarding the conversion process, particularly in determining the correct format for the answer. The final result should be expressed in three significant figures as 1070 nm. This demonstrates the importance of correctly applying the wavelength-frequency relationship in physics.
jcvince17
i just need to convert 2.8*1014 into nano meters
\lambda = v / f
\lambda = v / f
\lambda = 2.0*108 / 700*10-9 (nanometers)
\lambda = 2.8*1014
i am backwards on my conversion, i am horrible at it.
is it:
A - 2.80000000 nm
or
B - .00000028 nm
it wants my answer to three sig fig's
I'm guessing it's a frequency of 2.8^14 hz the OP wants to convert into a wavelegnth.
wavelength * frequency = speed.
so wavelength = c/f = 3e8 m/s / 2.8E14 /s = 1.07e-6m = 1070 e-9m
yes that got the first problem correct.
thanks
