How can I convert watt-hrs per gallon to watts?
  • Thread starter Thread starter tacojohn
    Watts
To convert watt-hours per gallon to watts, it's essential to understand the difference between energy (watt-hours) and power (watts). One gallon of gasoline contains approximately 33.3 kilowatt-hours of energy, which is equivalent to about 120 million BTU. The relationship between miles per gallon (mpg), miles per hour (mph), and gallons per hour can help determine power in watts. By converting gallons into watt-hours, one can derive the power output in watts. Understanding these conversions clarifies the calculation process for determining power from fuel consumption.
tacojohn
I'm trying to figure out how to convert watt-hrs per gallon to watts. If anyone can help it would be much appreciated!
Thanks. ^_^
watt-hours is a unit of energy. Watts are a unit of power - so one watt for one hour would be a watt-hour
1 gallon of gasoline contains about 120 million btu of energy. 1 kilowatt-hour of energy is equivalent to 3.6 million btu. So 1 gallon of gasoline contains about 33.3 kilowatt-hours of energy.
Well I'm converting a car's power to watts, knowing the mpg at a specific mph and watts-hr per gallon. So I'm slightly confused because if read that you can not change watt-hr to watts?
Can you shed some light on this for me?
mpg and mph gives you gallons/hour = power
If you convert gallons into watt hours then you get power in watts
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
