Converting wood joists to steel
  • Thread starter Thread starter fiddlesticks
    Steel Wood
Converting wood joists to steel requires calculating the equivalent cross-sectional moment using loading equations, as no specific guides exist for this conversion. Structural engineers typically perform these calculations to determine the appropriate steel dimensions. The USDA offers a free handbook with valuable engineering data on wood, which can assist in understanding the properties of the original material. A shared link to this handbook was appreciated by participants in the discussion. This resource can be beneficial for those looking to make the conversion.
fiddlesticks
I would like to know if there are any guides or tables that will allow you to convert 2x Douglas Fir joists to an equivalent rectangular steel tube.
There is no guide that I am aware of. I would imagine any structural engineer would simply run loading equations to calculate the required cross sectional moment required for the new material.
Oooohhhh... straight into my bookmark file. Nice link, Fred. :cool:
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
10K
